Discover the new Homey Portal
Blog Behind the Magic
Homey v2.0 — Devices & Flow
Behind the Magic
Devices
Your home is not so simple
Homey smart devices
For example, selecting First Floor shows all devices in First Floor, but also Bedroom, Bathroom and Study, as these are part of the First Floor. And saying "Turn off all devices on the first floor" as speech command finds those devices and turns them off.
Supporting 50.000 devices
Homey smart devices
To accomplish this, Homey defines devices based on their capabilities. These are properties like Turned OnBrightness and Color. We define the most-used capabilities for developers to use. Devices that do something special can create their own capability.
Device settings
Some devices, such as wall plugs, have a special setting: "What's plugged in?". Selecting a light, for example, will make the device behave like a light in both the UI, Flow and speech commands.
Homey smart devices
Homey smart devices
Adding a device
Homey smart devices
Homey smart devices
Device Insights
  • a timeline, which shows Yes/No values such as Turned On and Alarm went off.
  • charts, made by numeric values such as sensor values and energy usage.
Homey smart devices
Flow
Homey Flow
Homey Flow
Starting Flows manually
Homey Flow
Or and Else
Tags
Flow tags are those colored things that create more advanced Flows. For example, a tag can be the name of a user that just came home, so you can say "Welcome home, <name>".
A Flow has two kind of tags:
  • Local tags, provided by the Flow event card
  • Global tags, provided by Homey
Homey Flow
