Discover the new Homey Portal
Control Any Smart Home Device with Apple Home Using Homey
Not all smart home devices work with Apple Home directly. Many devices use different protocols, apps, or radio technologies, and some don’t support Apple Home or HomeKit at all.
To control supported smart home devices in Apple Home, you need a smart home hub that can connect to those devices and expose them to Apple’s HomeKit framework.
Homey acts as that bridge.
Homey connects to your devices using their native technologies and exposes them to Apple Home through the Apple HomeKit integration. Homey remains in control of the devices and Apple Home becomes an additional way to interact with them.
As long as Homey supports the device, it can typically be exposed to Apple Home in a compatible form.
What you need
To control smart home devices via Apple Home, you need:
All devices must be added to Homey first, before they are added to Apple Home.
What “exposing devices” means
When Homey exposes a device to Apple Home, it shares that device with Apple Home using the HomeKit protocol.
The device:
  • stays paired with Homey
  • becomes visible in Apple Home as a HomeKit accessory
Apple Home does not communicate with your devices directly. Instead, Apple HomeKit communicates with Homey, and Homey controls the devices using their native technology.
A simple way to think about it: Homey translates different device technologies into HomeKit-compatible accessories.
How to expose devices to Apple Home with Homey
Exposing devices is managed from within Homey. You do not need to re-pair devices or change how they are connected.
The process works like this:
  1. Add devices to Homey
    Pair or connect your devices to Homey and make sure they work correctly.
  2. Enable the Apple HomeKit integration
    In the Homey app or Web App, enable the Apple HomeKit experiment.
    Homey will generate a HomeKit pairing code.
  3. Add Homey to Apple Home
    Open the Apple Home app, choose Add Accessory, and scan the HomeKit code shown in Homey.
    Homey is added as a HomeKit bridge.
  4. Select which devices to expose
    In Homey, choose which devices should be exposed to Apple Home.
After adding Homey as a bridge, Apple Home imports the selected devices automatically.
No additional pairing steps are required in Apple Home.
How the connection works
  1. Devices connect to Homey
    Homey communicates with devices using their native technologies (Zigbee, Z-Wave, IR, 433 MHz, Wi-Fi, etc.)
  2. Apple HomeKit connects to Homey
  3. Homey forwards commands
    When you control a device in Apple Home or via Siri, Homey translates the command and sends it to the device.
What you can do in Apple Home
Once exposed, devices appear in Apple Home as standard HomeKit accessories, depending on their capabilities.
You can:
  • Use Siri voice commands
  • Assign devices to rooms
  • Include them in scenes
  • Use them in basic HomeKit automations
What to keep in mind
  • Not all device features are available in Apple Home
  • Some devices (such as infrared or 433 MHz devices) may not report their real-time state
  • Advanced automation logic stays in Homey
Use Apple Home for control, scenes, and voice interaction. Use Homey for advanced automation and cross-technology coordination.
In short
Apple Home doesn’t need to support every device technology directly.
Homey connects your smart home devices and exposes them to Apple Home in a consistent, HomeKit-compatible way — regardless of how they communicate underneath.
Apple Home becomes a simple, unified way to interact with your entire smart home and Homey stays in control.
