Which Thread Devices Make Sense Today? Practical Buying Advice for Homey Users
Where Thread is Ready to Deliver Today
Thread and Matter may still be the new kids on the block compared to Zigbee and Z-Wave, but in some areas, they’re already proving their value in real homes. If you're using Homey Pro or Homey Pro mini, certain categories of devices are a natural fit for Thread — not just in theory, but in practice.
Devices like contact sensors, motion sensors, smart plugs, and basic switches or buttons are small, low-power, and relatively straightforward. That’s where Thread excels. These products are simple enough that Matter’s current feature set covers them well, and their compact, battery-friendly nature matches Thread’s design goals perfectly.
Homey Best Buy Guide: Smart Plugs Featured
More importantly, multiple vendors are actively producing devices in these categories. While firmware updates are still ironing out some early wrinkles, it’s clear that manufacturers are learning quickly — and users are benefitting.
So if you’re just starting to adopt Thread in your Homey-powered smart home, these are ideal places to begin. They’re reliable, efficient, and already supported by Homey’s automation layer.
Where Other Protocols Still Lead The Way
That said, there are areas where Zigbee, Z-Wave or Wi-Fi remain ahead. Devices with more advanced features — like smart lighting with dynamic scenes, or locks that require certified security flows — still tend to be more mature in the older ecosystems. Specialized devices such as presence multi-sensors or air quality monitors, and media devices like TVs and AV receivers, are also more robustly integrated via Wi-Fi or vendor-specific APIs at this stage.
In these cases, Homey shines by being protocol-agnostic. You can continue using Zigbee for your lighting, Z-Wave for your heating control, and Wi-Fi for your sound system — all while introducing Thread devices where they make the most sense. There’s no need to replace what already works.
Thread as a Smart Investment For the Future
Even if some Z-Wave or Zigbee options are slightly better right now, Thread and Matter offer an important strategic benefit. Devices that support Matter-over-Thread are more likely to remain compatible with future ecosystems. They’re less dependent on proprietary bridges, and they’re designed with long-term interoperability in mind.
For new installations — especially simple devices that you expect to keep for years — choosing Thread gives you peace of mind. You’re buying into a future that leans toward open standards, even if it’s not quite universal yet.
A Practical Buying Approach for Homey Users
If you’re building or expanding your Homey smart home today, a smart strategy might look like this:
  • Choose Thread and Matter for new sensors and switches in areas where you don’t already have coverage. That might mean adding a Thread-based contact sensor to a new door, or placing a battery-powered Thread motion sensor in a hallway.
  • Choose Thread smart plugs for circuits you want to monitor long-term — their low power draw and growing Matter support make them great candidates for energy tracking.
At the same time, keep using Zigbee, Z-Wave or Wi-Fi for more complex tasks. If you already have a working mesh of Zigbee sensors or rely on Z-Wave heating controls, there’s no rush to replace them. Use Wi-Fi where bandwidth or vendor-specific features demand it — such as for cameras, AV equipment, or integrated appliances.
Over time, as Matter and Thread evolve, you can lean more heavily into the ecosystem. But there’s no need to go all-in today. With Homey, everything already works together — so your smart home grows at your pace, not the industry’s.
Conclusion: Thread is Ready — For the Right Jobs
Thread isn’t a full replacement for Zigbee or Z-Wave yet. But it is an excellent addition — especially for low-power, simple devices that you want to just work, quietly and reliably, for years to come. With Homey as your smart hub, you don’t have to choose a single winner. You can build your home room by room, use the best protocol for the job, and trust Homey to bring it all together.
Thread devices are at their best when they’re unremarkable:
  • They pair smoothly.
  • They stay online.
  • They don’t demand attention.
Today, that’s mostly true for simple but important categories like plugs and small sensors.
FAQ – Choosing Thread Devices
Should my next smart plug be Thread/Matter?
If you can get a good Matter-over-Thread plug that’s known to work well, yes, it’s a good candidate.
Are Thread sensors better than my existing Zigbee ones?
Not automatically. The main difference is standards and future interoperability, not day-one performance.
Is it worth replacing working Zigbee/Z-Wave devices with Thread?
Usually no. Replace devices when they fail or when you’re adding new functionality.
Do all Thread devices work with Homey?
Homey currently supports Matter devices over Thread, not arbitrary Thread-only products.
Is vendor choice still important in a Matter world?
Yes. Matter defines behavior, but implementation quality varies. Stick with vendors that ship updates and document Homey behavior well.
Can I mix Thread and Zigbee sensors in the same room?
Absolutely. Homey will happily treat them both as sources of triggers.
Glossary – Buying Terms
Device Class
A category of device, such as smart plug, motion sensor, thermostat, etc. Different classes mature at different speeds in new standards.
Early Adopter Risk
The chance that first-generation devices in a new standard have more bugs or missing features than later ones.
Bridge-Free Device
A device that connects directly to IP or Thread/Matter without a vendor-specific bridge.
Ecosystem Lock-In
When devices depend so heavily on a single vendor’s hub or cloud that migrating away becomes difficult.
Firmware Maturity
The degree to which a device’s software stack has undergone iterations and bugfixes in real-world deployments.
Multi-Admin
The ability for multiple controllers (Homey, Apple, Google, etc.) to manage the same Matter device.
Retrofit
Adding smart devices to an existing home without extensive structural changes. A key driver for wireless protocols.
Capability Mapping
How a platform like Homey translates Matter or Zigbee/Z-Wave device features into its own internal capabilities.
