What Is Matter Bridge and How Does It Work With Homey?
The Matter Bridge app for Homey allows users to share Homey-connected devices with other Matter controllers in your smart home. It acts as a link between Homey and major smart home ecosystems so that devices paired to Homey can also appear in platforms like Apple Home, Google Home, Amazon Alexa, Samsung SmartThings and Home Assistant. This gives users more choice in how they control, automate and interact with devices in their smart home.
Contents
- What is Matter Bridge?
- How Does Matter Bridge Work?
- Benefits of Using Matter Bridge
- Bridging Homey with Apple Home
- Bridging Homey with Google Home
- Bridging Homey with Amazon Alexa
- Bridging Homey with Samsung SmartThings
- Bridging Homey with Home Assistant
- Supported Device Types
- Limitations and Compatibility Notes
Matter Bridge is an official Homey app that allows selected Homey devices to appear in other smart home ecosystems that support the Matter standard. Once set up, these devices show up in multiple platforms at the same time, giving users the freedom to use their preferred app, voice assistant or interface without changing how their home is set up. Homey stays in full control of the devices while the other ecosystem gains access to essential controls such as on and off, dimming, temperature settings or sensor data.
Under the hood, Matter Bridge exposes Homey controlled devices through the Matter standard so that other controllers can recognize them as Matter accessories. This is particularly useful when a device is not natively supported by Apple Home, Google Home, SmartThings or other ecosystems. For example, a Zigbee or Z-Wave device paired to Homey can appear as a Matter device to external platforms. Matter Bridge works locally on your home network, supports secure communication and allows your devices to be shared without re-pairing or rebuilding your setup.
The Matter Bridge app works by translating Homey’s internal device capabilities into the unified format defined by the Matter standard. Homey acts as the primary smart hub and continues to run the device drivers, flows and automations. Matter Bridge then exposes a simplified version of each supported device to external controllers. This ensures that the ecosystem receiving the device sees a clean and compatible Matter accessory, while the advanced handling logic stays inside Homey. External platforms interact with the bridged device through Homey, not directly with the device hardware.
When another controller, such as Apple Home or Google Home, connects to Matter Bridge, it discovers the exposed devices using secure local networking. Depending on your Homey Pro model and setup, this can use Wi-Fi, Thread or Ethernet. Because communication remains local, commands sent from an external platform are fast and do not require a cloud round trip. Matter Bridge also keeps the device state synchronized across ecosystems so that when a device turns on through Homey, it updates instantly in the other platform and vice versa.
Using Matter Bridge gives users practical advantages across different platforms while keeping Homey as the main controller. Some of the key benefits include:
- Voice control everywhere: Devices connected to Homey can be controlled through Siri, Google Assistant or Alexa, depending on which ecosystems you use at home.
- Multi-ecosystem freedom: Households with mixed devices can interact with the same Homey connected accessory using whichever app or ecosystem they prefer.
- Extended compatibility: Older or non Matter devices such as Zigbee, Z-Wave or IR accessories paired to Homey can appear in other ecosystems as Matter devices.
- Shared automations: Devices exposed by Matter Bridge can participate in routines inside other ecosystems while Homey continues running its own flows.
- Reduced duplication: You pair a device once with Homey and Matter Bridge shares it where needed, removing the need to set up each device multiple times.
- Privacy and local control: Matter Bridge works locally inside your home network, so commands stay private, respond faster and continue functioning even if the internet is unavailable.
- Future proof setup: As Matter adoption grows, bridging ensures your Homey system remains compatible with new features and controllers without rebuilding your smart home.
Bridging Homey devices into Apple Home gives Apple users a familiar and polished interface for controlling their Homey connected devices. Devices appear in the Apple Home app just like native HomeKit accessories and can be organized into rooms, scenes and automations. This is especially helpful for households that rely on HomePods, Apple Watches or Siri voice control throughout the day, since Homey devices become accessible across the entire Apple ecosystem.
Because Apple Home integrates deeply with Apple hardware, Homey devices bridged over Matter work seamlessly alongside HomeKit-only products. A Homey Zigbee sensor can trigger a HomeKit camera recording, and a Homey controlled light can join a scene with Apple-only bulbs. This lets Apple users enjoy a smooth, unified experience without leaving Homey or giving up Apple’s convenience and privacy focused design.
Bridging Homey devices into Google Home brings them into the Google Home app and makes them available to Google Assistant. This works well for Android heavy households or users who rely on Nest speakers and displays. Devices like thermostats, sensors and lights appear in the Google Home interface and can be controlled with commands such as “Hey Google, turn off the hallway lights”.
Google Home routines can also include Homey exposed devices, allowing users to build mixed ecosystem routines. For example, a door sensor paired to Homey can start a Google Home routine that pauses a Nest speaker or turns on a Google only camera feed. It expands Google Home’s capabilities without changing your Homey setup.
Bridging Homey devices into Amazon Alexa lets Echo speakers and the Alexa app control Homey managed accessories as if they were Alexa-native. This is especially useful for homes where Echo devices act as room assistants or where Alexa voice control is already part of the daily routine. Commands like “Alexa, turn on bedroom lights” work even when those lights are paired only to Homey.
Alexa routines offer many practical options for users who prefer Amazon’s automation style. A Homey controlled smart plug can be added to routines that involve Echo announcements, Guard mode or time-based triggers. Alexa motion sensors inside Echo speakers can also trigger Homey lights through the bridged device. It’s a simple way to combine Homey’s wide device support with Alexa’s voice-first environment.
Bridging into Samsung SmartThings makes Homey devices available inside the SmartThings app, which is especially valuable for households that own Samsung appliances or TVs. It allows Homey controlled lights, switches and sensors to sit next to Samsung fridges, washing machines, ovens or air conditioners in a single app. This brings extra convenience to users who already use SmartThings in their smart home.
Because SmartThings ties appliance data, routines and home control into one platform, Homey devices can take part in more complete whole-home scenarios. A Homey managed motion sensor can help trigger a Samsung air conditioner, or a Homey light can adjust brightness based on a routine that includes a Samsung TV. This setup lets SmartThings users expand their system without giving up Homey’s broader hardware compatibility.
For advanced tinkerers or enthusiasts, making Homey devices available in Home Assistant opens the door to powerful dashboards and custom automations. Devices paired to Homey appear in Home Assistant as Matter entities, which means users do not need to pair anything twice. This setup works particularly well for households that enjoy building custom interfaces or combining many types of hardware in one place.
Home Assistant allows Homey devices to work alongside DIY sensors, ESPHome projects or integrations specific to Home Assistant. A Homey light can be part of a Home Assistant automation that includes a locally built sensor or a server-based logic system. This creates a flexible hybrid setup where Homey handles reliable device management while Home Assistant adds deep device customization.
Matter Bridge supports a wide range of everyday smart home devices. While capabilities may vary between ecosystems, the following categories are generally compatible when shared through the Matter Bridge app:
- Smart Lights and LED Strips
- Smart Plugs and Sockets
- Smart Thermostats and Temperature Controls
- Smart Locks
- Smart Blinds, Curtains and Roller Shutters
- Smart Door and Window Sensors
- Smart Temperature and Humidity Sensors
- Smart Motion and Presence Sensors
- Smart Air Quality Monitors
- Smart CO₂ and Smoke Detectors
Matter Bridge exposes only the features defined by the Matter standard and supported by the receiving ecosystem. This means that advanced Homey features such as energy reporting, multi channel devices, or specialized settings may not appear in the external platform. Some devices may show only basic controls like on and off, brightness or temperature.
Each ecosystem may also interpret Matter features differently. For example, Google Home may display certain device types that Apple Home does not, and SmartThings may expose fewer capabilities than Home Assistant. Homey remains the primary controller, so if Homey loses access to a device due to network or power issues, the bridged device will become unavailable across all ecosystems until Homey is restored.
