Discover the new Homey Portal
Automate Your Garden and Plant Care with Homey
A beautiful garden and healthy houseplants bring life to your home. But providing the right amount of water, light, and protection requires constant attention. Simple timers and tools can't adapt to the changing needs of your plants or the environment.
When you connect smart devices to Homey, you create an intelligent assistant for your garden and plant care. This system automates the hard work, ensuring your plants get exactly what they need to thrive, whether they are inside or outside your home.
Intelligent Watering That Watches the Weather
A fixed watering schedule often does more harm than good because it completely ignores the weather. Homey makes your watering intelligent by linking your irrigation controller, like a Gardena Smart Water Control, directly to the local forecast. It automatically skips watering when rain is on the way and provides extra water during a heatwave. This adaptive approach ensures your plants get exactly what they need, keeping your garden healthy while saving water.
Automate Your Garden and Plant Care with Homey Watering Flow
For more targeted care, you can use wireless soil moisture sensors. By installing a soil moisture sensor from a brands like Thirdreality or FYTA in a vegetable patch or an important indoor pot, you can create a dedicated Homey Flow, watering that specific area only when the soil becomes too dry. This precision prevents root rot and gives each plant the individual attention it needs to flourish.
Perfect Lighting for Thriving Plants
Proper light is just as important as water, especially for your indoor plants. With Homey and a smart light sensor, you use both natural and artificial light intelligently. If it becomes too dark and overcast, a Flow can automatically open your smart curtains to maximize any available sunlight. For days when even that is not enough, or for seedlings needing a boost, Homey can turn on smart grow lights to provide the perfect amount of supplemental light.
Automate Your Garden and Plant Care with Homey Low Light Level Flow
This smart control also works the other way to protect your more delicate plants. Some plants are sensitive and can be damaged by too much direct sunlight. Homey can use a light sensor to monitor the sun's intensity. If the sensor detects extreme brightness for a prolonged period, a Flow can automatically close your window coverings in the greenery, providing shade and protecting your sensitive plants from getting scorched.
Precision Care for Different Plant Needs
Different plants require more than just the right amount of water. Their health also depends on specific soil conditions. For a deeper understanding of your plant's needs, you can use an advanced sensor like the FYTA Beam. This smart device does more than just read moisture. It measures nutrient levels, soil pH, temperature, and light right at the root, giving you a complete picture of its environment.
With this information, you can create powerful Homey Flows. For example, if the FYTA sensor detects that the nutrient level for your tomato plants is low, Homey can send you a specific notification. The alert might say, 'Nutrients are low for the tomatoes. It is time to fertilize.' This turns you into a plant expert, providing precise guidance to care for each one individually.
Protecting Your Garden from Frost and Extreme Weather
Sudden temperature drops can undo weeks of careful plant care. An outdoor temperature sensor lets Homey watch for frost risk overnight. When readings fall near freezing, a Flow can alert you before damage happens.
This same Flow can take action on its own. It can extend a smart cover over sensitive beds or trigger a connected greenhouse heater to switch on. Your plants stay protected without you needing to check the forecast at midnight.
Extreme heat deserves the same attention. If a heatwave pushes temperatures too high, Homey can trigger shade cloths or extra watering automatically, keeping stress on your plants to a minimum during the worst of it.
Get Started Today
Don't wait to create a garden that practically takes care of itself. With Homey, you can build an intelligent plant care system today. Get started for free with Homey Cloud, or go full-on with Homey Pro. Get started for free with Homey Cloud, or go full-on with Homey Pro.
FAQs
Can Homey skip watering automatically when it's about to rain?
Yes. By linking an irrigation controller to the local forecast, Homey can skip scheduled watering when rain is expected and add extra water during a heatwave.
How do soil moisture sensors improve watering accuracy?
A wireless soil moisture sensor placed in a specific pot or bed lets Homey water only that area when the soil actually becomes dry, preventing root rot.
Can Homey protect plants from too much direct sunlight?
Yes. A light sensor can detect prolonged intense sunlight and trigger a Flow to close window coverings, shading sensitive plants from scorching.
What can an advanced sensor like the FYTA Beam measure?
It reads nutrient levels, soil pH, temperature, and light at the root, giving a full picture of a plant's growing conditions beyond just moisture.
Do I need Homey Pro for garden automation?
Homey Cloud can run basic watering and lighting Flows for free, while Homey Pro adds local processing and support for more sensor and irrigation brands.
Flow
A rule in Homey that connects a trigger, such as a sensor reading or a weather condition, to one or more automated actions.
Irrigation Controller
A device that manages watering schedules for a garden or lawn, and can be connected to Homey for weather-based automation.
Soil Moisture Sensor
A wireless sensor placed in soil that measures water content, allowing Homey to water only when a plant actually needs it.
Frost Risk
A condition where falling temperatures threaten to damage or kill plants, often detected using an outdoor temperature sensor.
Grow Light
An artificial light designed to supplement or replace natural sunlight for plants, often used for indoor gardens or seedlings.
