![KNX Explained – What is KNX?](https://blog.athom.com/wp-content/uploads/2019/06/knx-1024x512.jpg)
KNX is a standard for wired home automation and building automation. It exists since 1999 and describes how sensors and actors can communicate. the standard is governed by the KNX Association. Building a KNX system is expensive, especially in already-built houses: new cables and ducts need to be installed in the walls to every wall switch, sensor, light point or outlet.
KNX in practice
Alternatives for Smart Homes
For smart homes, most people choose wireless home automation. New technologies like Z-Wave systems or Zigbee replace older, wired options. New cables, wiring and ducts are not necessary anymore - adding smart devices to your home becomes a lot simpler. Relocating devices in a home is also much easier, and there is no installer necessary.
![Homey Pro combines all your smart home products, including KNX devices, in a single interface.](https://blog.athom.com/wp-content/uploads/2023/07/Homey-Pro-Mobile-App-Web-App-e1690788806886.png)
KNX & Homey
If you already have an existing KNX system at home, and if you want to combine that with Sonos, Philips Hue, Fibaro, Xiaomi Aqara or other wireless Smart Home devices, there's good news. It is possible to link Homey to a KNX network!
![](https://blog.athom.com/wp-content/uploads/2023/08/Homey-Pro-Early-2023-—-Interior-5-edited-1-2000x1125.jpg)
Get started with KNX & Homey
- Access to your home from anywhere in the world
- Combine KNX and other, wireless devices in one interface
- Automate your entire home, across systems, with Homey Flow
- Control your devices, including KNX, via Amazon Alexa and Google Assistant
- Enjoy a real smart home, anno 2024
If you want to get started, we suggest you check out our article on creating a KNX smart home with Homey. Want more information on Homey and all its capabilities? Then we welcome you to discover Homey Pr.
