KNX Explained – What is KNX?
Updated 2 months ago 5 minutes
KNX wired home automation system
This is what KNX wiring looks like
KNX in practice
The above reasons make that KNX is mostly used to automate large buildings and projects, like concert venues and office buildings. For home automation there are alternatives that are more flexible, cheaper and more approachable. Especially with the recent rise of wireless technologies and Smart Home. That’s why a lot of people are looking for options to make a KNX smart home, and combine their KNX system with smart home products.
Alternatives for Smart Homes
For smart homes, most people choose wireless home automation. New technologies like Z-Wave systems or Zigbee replace older, wired options. New cables, wiring and ducts are not necessary anymore – adding smart devices to your home becomes a lot simpler. Relocating devices in a home is also much easier, and there is no installer necessary.
KNX and Homey app
The Homey App combines all your KNX and other smart devices
KNX & Homey
If you already have an existing KNX system at home, and if you want to combine that with SonosPhilips HueFibaro, Xiaomi Aqara or other wireless Smart Home devices, there’s good news. It is possible to link Homey to a KNX network!
This link allows all your devices to show up in the Homey smartphone app – anywhere in the world. View all your devices, KNX or not, in a single interface. You can also use the powerful Homey Flow to automate your home. Combine KNX with wireless smart home devices in your own scenes and scenarios.
Make you KNX installation wirelessly accessible with Homey
Get started with KNX & Homey
To link your system with Homey you need a KNX/IP Gateway. Combined with a Homey Pro, it just costs 569 euros, and includes everything you need for the entire link and visualisation, including:
  5. Enjoy a real smart home, anno 2021
If you want to get started, we suggest you check out our article on creating a KNX smart home with Homey. Want more information on Homey and all its capabilities? Then we welcome you to discover Homey.
Subscribe to our newsletter and be on top-of-mind about new Homey features, exclusive offers and more.
