KNX Explained – What is KNX?
KNX in practice
Alternatives for Smart Homes
Homey Pro combines all your smart home products, including KNX devices, in a single interface.
The Homey App combines all your KNX and other smart devices.
KNX & Homey
If you already have an existing KNX system at home, and if you want to combine that with Sonos, Philips Hue, Fibaro, Xiaomi Aqara or other wireless Smart Home devices, there's good news. It is possible to link Homey to a KNX network!
Make you KNX installation wirelessly accessible with Homey Pro
Get started with KNX & Homey
  5. Enjoy a real smart home, anno 2026
If you want to get started, we suggest you check out our article on creating a KNX smart home with Homey. Want more information on Homey and all its capabilities? Then we welcome you to discover Homey Pro.
