KNX Explained – What is KNX?
KNX in practice
Alternatives for Smart Homes
KNX and Homey app
The Homey App combines all your KNX and other smart devices
KNX & Homey
If you already have an existing KNX system at home, and if you want to combine that with SonosPhilips HueFibaro, Xiaomi Aqara or other wireless Smart Home devices, there's good news. It is possible to link Homey to a KNX network!
Make you KNX installation wirelessly accessible with Homey
Get started with KNX & Homey
To link your system with Homey you need a KNX/IP Gateway. Combined with a Homey Pro, it just costs 569 euros, and includes everything you need for the entire link and visualisation, including:
  5. Enjoy a real smart home, anno 2021
If you want to get started, we suggest you check out our article on creating a KNX smart home with Homey. Want more information on Homey and all its capabilities? Then we welcome you to discover Homey.
