What is Zigbee? Explaining the World’s Most Popular Smart Light Network Technology
Zigbee logo
Zigbee At a Glance:
  • Wireless smart home technology
  • Works on the 2.4GHz frequency
  • Alternative to Z-Wave
  • Standardized wireless protocol, so devices from different manufacturers can talk to each other
  • Mesh networking
  • Cost-effective
  • Secure 128-bit AES encryption
  • Low-power usage / long battery life
  • Range: 10-20 meters indoors, 75-300 outdoors
  • IP connection for smartphone / tablet control when you connect a Zigbee hub
So, What is Zigbee?
Zigbee is a protocol used to link smart devices like lights, plugs, and smart locks to a home network. You can use this home network as-is with remote controls, like a Tradfri remote from IKEA. It won't be very smart, but everything is connected and you'll never have to get up to use a light switch. You can also link your Zigbee network to a hub like Homey. Here, Homey serves as a "bridge" to the Internet, offering cloud tools, apps, and (remote) control from your phone.
Zigbee is similar to, but different from, competing protocols like Z-Wave, Wi-Fi, and Bluetooth. They all create relatively secure networks, which you can (mostly) connect to a hub and control with your phone or a desktop app. Zigbee has pros and cons. The largest differences to you, as a user, are supported devices, with Zigbee offering more in terms of lights and smart plugs where other protocols support different smart devices.
Zigbee Basics: How It Works
  • Zigbee devices can send and receive data from other Zigbee devices
  • A single hub can connect to multiple devices
  • Zigbee offers device-to-device communication, relaying messages for a larger effective range
Mesh Networking
Mesh network on Zigbee with Homey
Mesh networking, like Zigbee has, means nodes can relay signals, increasing the effective range.
Let’s look at an example:
What’s in a Zigbee Network?
A Zigbee network with the different roles for Coordinator, Router and End-Device shown.
Coordinator – Every network needs an administrator. For Zigbee, that's the coordinator. The coordinator sets up the Zigbee network. You need one per network. This role is normally taken by the Zigbee hub, such as the Philips Hue Bridge, our one and only Homey, or other devices. Your coordinator does not have to be a smart hub, but it is recommended, as this is the most powerful setup.
The coordinator serves as the central point to your network, where you can set permissions, allow other devices access, and coordinate your Personal Area Network (PAN). If you're using a hub, it's also where you link your devices to the web and apps. And, hubs like Homey connect your Zigbee devices to devices that might use other protocols, like Wi-Fi, infrared, or Z-wave
Zigbee's power-efficiency allows for small devices
Why Use Zigbee?
Better Remotes – If you have RF or Infrared lights at home, you'll be pleased to know Zigbee is much better. If you do use a remote, you can point it anywhere to activate the connected device. Still, we'd recommend a smart hub, and that's not just because we're selling one. Smart hubs allow you to connect your Zigbee network to the web so you can use your phone as a remote, set up automation, and control your devices when you're not at home.
Cost-Effective – Zigbee devices are notoriously affordable. Zigbee devices tend to be 20-50% cheaper than Z-Wave devices with the same functions. Since both the chips and the certification are easier and cheaper on Zigbee compared to Z-Wave, this difference will probably last.
  • You always need a hub like Homey to pair Zigbee to your mobile phone or a computer.
  • Zigbee networks have a limited range if you don’t add on more devices. Every Zigbee device must be within the limited range of at least one other Zigbee device at all times.
  • Not every smart device supports Zigbee. While Zigbee dominates the smart light market, you're very likely to need another technology if you want sensors, switches, Tvs, fans, or data streaming devices.
Getting Started with Zigbee
Step 1: Buy a smart hub. We obviously recommend Homey
Step 3: Setup your hub.
At the end of the day, most smart home technologies have a lot to offer. Zigbee is just one option. And, with smart home hubs like Homey offering support for multiple protocols, there’s no real reason all your devices have to use the same protocol. Homey supports 6 smart home technologies, including Zigbee. Your ideal smart home likely includes a mix of technology, which is why it’s more important that your central hub support everything you need to automate your home.
Discover Homey »
Subscribe to our newsletter and be on top-of-mind about new Homey features, exclusive offers and more.
