What is Zigbee? Explaining the World’s Most Popular Smart Light Network Technology
Zigbee At a Glance:
- Wireless smart home technology
- Works on the 2.4GHz frequency
- Popular, relatively affordable alternative to Z-Wave, Matter, Wi-Fi and Bluetooth
- Standardized wireless protocol, so devices from different manufacturers can talk to each other
- Uses Mesh networking
- Cost-effective
- Secure 128-bit AES encryption
- Low-power usage / long battery life
- Range: 10-20 meters indoors, 75-300 outdoors
- IP connection for smartphone / tablet control when you connect a Zigbee hub
So, What is Zigbee?
Zigbee is a protocol used to link smart devices like lights, plugs, and smart locks to a home network. You can use this home network as-is with remote controls, like a Tradfri remote from IKEA. It won't be very smart, but everything is connected and you'll never have to get up to use a light switch. You can also link your Zigbee network to a hub like Homey. Here, Homey serves as a "bridge" to the Internet, offering cloud tools, apps, and (remote) control from your phone.
Zigbee Basics: How It Works
- Zigbee devices can send and receive data from other Zigbee devices
- A single hub can connect to multiple devices
- Zigbee offers device-to-device communication, relaying messages for a larger effective range
Mesh Networking
Let’s look at an example:
What’s in a Zigbee Network?
Coordinator – Every network needs an administrator. For Zigbee, that's the coordinator. The coordinator sets up the Zigbee network. You need one per network. This role is normally taken by the Zigbee hub, such as the Philips Hue Bridge, our one and only Homey, or other devices. Your coordinator does not have to be a smart hub, but it is recommended, as this is the most powerful setup.
The coordinator serves as the central point to your network, where you can set permissions, allow other devices access, and coordinate your Personal Area Network (PAN). If you're using a hub, it's also where you link your devices to the web and apps. And, hubs like Homey connect your Zigbee devices to devices that might use other protocols, like Wi-Fi, infrared, or Z-wave.
Why Use Zigbee?
Better Remotes – If you have RF or Infrared lights at home, you'll be pleased to know Zigbee is much better. If you do use a remote, you can point it anywhere to activate the connected device. Still, we'd recommend a smart hub, and that's not just because we're selling one. Smart hubs allow you to connect your Zigbee network to the web so you can use your phone as a remote, set up automation, and control your devices when you're not at home.
- You always need a hub like Homey to pair Zigbee to your mobile phone or a computer. Also, Zigbee is limited to one hub per system, unlike Matter.
- Zigbee networks have a limited range if you don’t add on more devices. Every Zigbee device must be within the limited range of at least one other Zigbee device at all times.
- Not every smart device supports Zigbee. While Zigbee dominates the smart light market, you're very likely to need another technology if you want sensors, switches, Tvs, fans, or data streaming devices.
Getting Started with Zigbee
Step 1: Buy a smart hub. We obviously recommend either Homey Bridge or Homey Pro.
Step 3: Setup your hub.
Discover Homey Pro »
