🖤 Save 700 kr on Homey Pro and up to 29% on everything else No code needed • Discount automatically applied at checkout
What is Zigbee?
What is Zigbee?
Explaining the World’s Most Popular Smart Light Network Technology
Zigbee logo
Zigbee At a Glance:
  • Wireless smart home technology
  • Works on the 2.4GHz frequency
  • Popular, relatively affordable alternative to Z-Wave, Matter, Thread, Wi-Fi and Bluetooth
  • Standardized wireless protocol, so devices from different manufacturers can talk to each other
  • Uses Mesh networking
  • Cost-effective
  • Secure 128-bit AES encryption
  • Low-power usage / long battery life
  • Range: 10-20 meters indoors, 75-300 outdoors
  • IP connection for smartphone / tablet control when you connect a Zigbee hub, like Homey Pro
So, What is Zigbee?
Zigbee is a protocol used to link smart devices like lights, plugs, and smart locks to a home network. You can use this home network as-is with remote controls, like a Tradfri remote from IKEA. It won't be very smart, but everything is connected and you'll never have to get up to use a light switch. You can also link your Zigbee network to a smart home hub like Homey. Here, Homey serves as a "bridge" to the Internet, offering cloud tools, apps, and (remote) control from your phone.
Zigbee Basics: How It Works
  • Zigbee devices can send and receive data from other Zigbee devices
  • A single hub can connect to multiple devices
  • Zigbee offers device-to-device communication, relaying messages for a larger effective range
Mesh Networking
Mesh network on Zigbee with Homey
Mesh networking, like Zigbee has, means nodes can relay signals, increasing the effective range.
Let’s look at an example:
What’s in a Zigbee Network?
A Zigbee network with the different roles for Coordinator, Router and End-Device shown.
Coordinator – Every network needs an administrator. For Zigbee, that's the coordinator. The coordinator sets up the Zigbee network. You need one per network. This role is normally taken by the Zigbee hub, such as the Philips Hue Bridge, our one and only Homey, or other devices. Your coordinator does not have to be a smart home hub, but it is recommended, as this is the most powerful setup.
The coordinator serves as the central point to your network, where you can set permissions, allow other devices access, and coordinate your Personal Area Network (PAN). If you're using a hub, it's also where you link your devices to the web and apps. And, hubs like Homey connect your Zigbee devices to devices that might use other protocols, like Wi-Fi, infrared, or Z-wave.
Zigbee's power-efficiency allows for small devices
Why Use Zigbee?
Better Remotes – If you have RF or Infrared lights at home, you'll be pleased to know Zigbee is much better. If you do use a remote, you can point it anywhere to activate the connected device. Still, we'd recommend a smart home hub, and that's not just because we're selling one. Smart hubs allow you to connect your Zigbee network to the web so you can use your phone as a remote, set up automation, and control your devices when you're not at home.
  • You always need a hub like Homey to pair Zigbee to your mobile phone or a computer. Also, Zigbee is limited to one hub per system, unlike Matter.
  • Zigbee networks have a limited range if you don’t add on more devices. Every Zigbee device must be within the limited range of at least one other Zigbee device at all times.
  • Not every smart device supports Zigbee. While Zigbee dominates the smart light market, you're very likely to need another technology if you want sensors, switches, Tvs, fans, or data streaming devices.
Homey Pro next to smart speaker
Getting Started with Zigbee
Step 1: Buy a smart home hub. We obviously recommend either Homey Pro or Homey Pro mini or opt for Homey Self-Hosted Server, which requires the Homey Bridge to support Zigbee.
Step 3: Setup your hub.
Using Zigbee with other smart home platforms
If you want to see how Zigbee devices work together with popular smart home platforms, Homey makes it easy to connect everything in one place. With Homey, you can integrate Zigbee devices with platforms such as Zigbee with Amazon Alexa, Zigbee with Google Home, and Zigbee with Apple Home, allowing you to control and automate your devices using voice assistants and familiar smart home apps. If you’d like a deeper look at how Zigbee works within the Homey ecosystem itself, you can also learn more about how Zigbee works with Homey and how it connects different devices into one flexible smart home system. Homey can also control Zigbee devices via Matter.
At the end of the day, most smart home technologies have a lot to offer. Zigbee is just one option. And, with smart home hubs like Homey Bridge and Homey Pro offering support for multiple protocols, there’s no real reason all your devices have to use the same protocol. Your ideal smart home likely includes a mix of technology, which is why it’s more important that your central hub support everything you need to automate your home.
Other smart home technologies supported by Homey
Zigbee is one of several technologies used in smart homes. Homey also supports other widely used standards such as Z-Wave, Matter, and Thread, as well as technologies like 433 MHz and KNX. Together with Zigbee, these technologies allow Homey to connect devices that use different communication standards in one flexible smart home system.
Discover Homey Pro »
