Enabling and disabling the Presence Simulation
Of course, by making a Flow like this your devices will always behave like they're simulating your presence. Even when you're at home! To prevent this from happening, simply add two Flows. One to enable the Presence Simulation when nobody is at home, and one to disable the Presence Simulation when someone comes home. It's easy to enable/disable Flows in the Flow Editor.
Smart triggers
In Homey's Flow Editor you’ll notice there’s an option to add smart triggers. These allow you to make a dynamic scenario, which fit every season. You’ll be able to leave your home carefree all year long, without worrying about rescheduling your timers. Take 'the sun sets' for example. Using this trigger, Homey will always execute certain tasks when the sun sets that day, instead of at a fixed time which is either too early or too late. This way you won't have to edit your Flows when seasons change.
Get creative!
