Discover what hardware is used around the world to monitor energy usage. Learn how smart energy readers — like the Homey Energy Dongle — can help you identify large consumers and optimize your household's energy use.
- Track real-time energy consumption
- Monitor electricity, gas, and water usage
- Discover smart energy meters used across the world
- Learn about alternative energy monitoring solutions
- Enable automation through smart home platforms — like Homey
What are Smart Energy Meters?
Types of Smart Energy Meters
P1 Readers
- DSMR 4.x and earlier: Basic functionality with limited data updates. Provides 5V at 100 mA, insufficient to power P1-connected readers.
- DSMR 5.x: Real-time updates with renewable energy systems support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
- DSMR 6.x: Real-time updates with smart grid integration and advanced encryption support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
Countries using P1 Readers:
- 🇳🇱 The Netherlands
- 🇧🇪 Belgium
- 🇱🇺 Luxembourg
- 🇩🇰 Denmark
- đź‡đź‡ş Hungary
- 🇸🇪 Sweden
- 🇫🇮 Finland
- 🇦🇹 Austria
- 🇱🇹 Lithuania
- 🇨🇠Switzerland
HAN Readers
Countries using HAN Readers:
- 🇳🇴 Norway
- 🇸🇪 Sweden
- 🇩🇰 Denmark
- 🇫🇮 Finland
Optical (Pulse) Readers
- 🇺🇸 United States
- 🇨🇦 Canada
- 🇬🇧 United Kingdom
- 🇦🇺 Australia
- 🇯🇵 Japan
- 🇪🇺 Most European Countries
Clamp Readers
