Homey for Installers
Homey is the most versatile smart home platform in the world. It offers 8 wireless technologies, integrates with over 1,000 brands, and supports over 50,000 devices. It’s the perfect foundation for any installation, making it highly appealing for installers like you.
Save time on every installation thanks to simple and fast interfaces. Combine your favorite solutions for home automation, entertainment, motorization, security, and more. Explore some of the interesting possibilities.
Become a Homey Certified Installer
Are you interested in using Homey in your installations? Become a Homey Certified Installer and enjoy some great benefits. For starters, you can use and leverage our trademarks in your communications. You will also be featured as an installation partner on our Where To Buy page for free new leads and receive installer pricing.
Excited? Simply apply to become a Homey Certified Installer through our application form. After your application has been reviewed, we will train and certify you, and you get the opportunity to purchase your first installer kit. Our training process is completely free of charge. Obviously, we do require your commitment to pass.
Homey + Solar inverters
Homey works with a wide range of solar inverter systems, including SolarEdge, Growatt, Enphase, SMA, Solis, Huawei, GoodWe, Fronius and others. Also, balkonkraftwerke are also supported through smart plugs from brands like Shelly, Fibaro, Aqara or others. By connecting solar panels to Homey, users can easily view their home's solar generation in beautiful graphs – and automate their home with solar triggers! Combined with all the other devices Homey can monitor and control, it fully integrates solar generation into the entire smart home experience.
Homey + HVAC
Smart thermostats, Split airconditioning systems and several heat pumps can be directly integrated in Homey. This means that for every HVAC setup – from a single A/C unit to a multi-room radiator or floor-heating system on either gas or heatpump, there's options to connect them to Homey. Homey works with smart thermostats like Tado, Nest, Netatmo, Plugwise, Honeywell, Heat-it, Ecobee and more, A/C systems including Daikin, LG, Mitsubishi HI and - Electric, Toshiba, Panasonic and through Broadlink, Tado or Sensibo, and Heatpumps either through the smart thermostat, or directly to Remeha, Daikin, LG and more. Combine comfort, savings and optimizing solar usage by linking HVAC to Homey.
Apply as Homey Certified Installer
Offer your customers a solution to combine over 1000 brands of Energy, HVAC and smart home devices. Provide them with a premium interface for their entire smart home. Get trained and certified as a Homey Certified installer for free.
Homey + Shelly
Shelly provides wireless smart home modules at attractive prices, which are fully compatible with Homey. Both the Wi-Fi based range of Shelly and the Z-Wave based Shelly Wave modules and devices are compatible with Homey.
Use Homey as the heart of your installation, and combine Shelly products with all the other possibilities of Homey. These include full-featured connections with Sonos, Philips Hue, Somfy, Fibaro, Aqara, Gardena, and even IKEA and KNX.
Homey + Fibaro
Homey works perfectly with all Fibaro Z-Wave modules. Fibaro modules link directly with Homey, so the Fibaro Home Center is not necessary anymore. Use Homey as the heart of your installation, and combine Fibaro products with all the other possibilities of Homey. These include full-featured connections with Sonos, Philips Hue, Somfy, Shelly (including Shelly Wave), Aqara, Gardena, and even IKEA and KNX.
Homey + Somfy
Somfy RTS motors can be directly controlled from Homey. Simply add the roller blinds, curtains, garage doors and other motorized products from Somfy in the Homey app. Now, you can control these devices directly from the Homey app, and include them in Flows. Combine Somfy with the 1,000+ other brands Homey works with for beautiful and practical scenes. Even Somfy io-homecontrol devices can be controlled through Homey when you connect a Somfy Connexoon io box.
Homey + KNX
Wired KNX systems can also be linked to Homey. Homey can visualize the entire KNX installation when connected to a simple KNX/IP gateway. After linking, the installation can be controlled from anywhere worldwide, included in Flows, and is available for voice control for Amazon Alexa and Google Assistant. Read more about Homey + KNX.
Homey + Sonos
Sonos’ entertainment systems are seamlessly integrated into Homey. With the tap of a button, Homey can scan the local network for Sonos devices, after which they will be added automatically. Control Sonos from anywhere in the world through Homey and the rest of the home. Use Flows to automatically play music based on your rules. You can even configure wall switches and other inputs to control Sonos.
Homey + Philips Hue
Light up your installation with Philip Hue. Homey fully supports the extended smart lighting range of this famous Dutch bulb brand. Choose from a vast array of options to create the perfect lighting in the homes you cater to. Tune and color automatically by combining Hue lighting with the other 1,000 supported brands in Homey Flow. Homey makes it effortless to create an installation where Z-Wave sensors, built-in modules, Somfy motors, Philips Hue, and even KNX work in sync.
Homey + Fibaro
Homey works perfectly with all Fibaro Z-Wave modules. Fibaro modules link directly with Homey, so the Fibaro Home Center is not necessary anymore. You can connect, set up and configure Fibaro modules directly in Homey Pro or Homey Bridge using Z-Wave Plus. This allows your customers to seamlessly use Fibaro devices together with the rest of their smart home setup.
Homey + 1,000 other brands
Over 1,000 brands work with Homey on one of the 8 wireless technologies and numerous communication protocols Homey features. From television sets or receivers via infrared to the latest sensors on Z-Wave and lighting sets on Zigbee, you can combine them all in the perfect setup with Homey. Under Homey’s open app platform, new brands and devices are added daily. Ease-of-use and versatility: Meet Homey.
