![Energy Management in a Smart Home](https://blog.athom.com/wp-content/uploads/2023/03/talks-with-homey-house-2000x750.jpg)
Contents
- What is HEMS?
What is a Home Energy Management System (HEMS)? - Energy management factors
What factors play a role in the way you generate and consume energy at home? - Separate solutions
Which solutions are available right now for the different factors? - Energy management systems and smart home
How can control, insight and automation be centralized, and what are the characteristics of a good energy management system? - Homey as HEMS
Learn how to use home as an effective energy management system
Several factors heavily influence how you use, pay, and manage energy in your home. Consider these factors when you select a home energy management system. Don’t stop at the factors that apply to you and your house right now. Instead, take some time to think about what factors will also play a role in the future. Further, devices like P1 Smart Meters are essential for understanding and optimizing your home’s energy footprint.
- Solar at home
- Type of heating and cooling: city heating (hot water), gas, heat pump, or electrical/radiant
- Major energy consumers and their buffering capacity
- Availability and use of EVs
- Availability and use of home energy storage, like home batteries
- Type of energy contract: fixed, variable or dynamic
Even if you don’t know all your plans yet, it’s good practice to stay as versatile as possible with your HEMS choice. Consider one that connects with many different solutions and covers a wide range of use cases. Homey, especially Homey Pro, is an energy management powerhouse!
Solar at home
For inspiration, check out Christian Doczekal’s use case for his Growatt solar panel system. Using Homey as a HEMS, he developed a system that cools his home during the summer with over 91% of the energy generated from his solar panels!
![Energy management - Solar on roof](https://blog.athom.com/wp-content/uploads/2023/03/Solar-on-roof.png)
Homey works with a wide range of photovoltaic systems, providing advanced insights to help you optimize their performance. Check out the best inverter and solar panels compatible with Homey to learn more.
Type of heating
Take inventory of your home’s biggest energy consumers. In addition to heating, these might include washers, dryers, dishwashers, saunas, pools, electric or induction stoves, ovens, and freezers. Some of these devices have a buffering capacity, meaning they can store energy, offering significant energy management opportunities. If you have a dedicated energy storage system (ESS), you can utilize you savings even further with Homey.
![EV Chargers Featured Image](https://blog.athom.com/wp-content/uploads/2024/06/homey-best-buy-guide-ev-chargers-featured-1856x752-1.jpg)
To get the most out of your EV and EV charger, it's beneficial to also integrate your vehicle with Homey. Almost all electric vehicle offer some type of connectivity and Homey works with many brands. You can monitor battery levels, charging status, driving range or even remotely control your car. Check out which EVs integrate with Homey and learn about their smart capabilities.
Connected solar at home
- Get a smart and connected inverter. For instance, inverters from EnPhase, Growatt, SolarEdge, SMA, Tigo, GoodWe, and Huawei can connect to Homey Pro to communicate their energy generation to you.
- Get a smart meter add-on that can measure your solar generation. This is usually called a ‘3-phase meter’. Brands like Eastron and Tibber have add-ons that can do this and connect to an energy management system like Homey.
Connected heating solutions
Even though heating systems differ a lot, they are all controlled by thermostats. Nowadays, there are smart thermostats available for almost every heating setup. Ideally, you need a thermostat that your home energy management system can control for energy efficiency and savings. Homey is compatible with a wide range of thermostats for multiple heating configurations:
- Multi-zone heating with different thermostats. This is popular in Scandinavian countries like Norway and Sweden. Brands like Heat-it have connected room thermostats for this option.
- Heating with a main thermostat (either single or multi-zone). This is popular in Western Europe. Brands like Honeywell Evohome, Tado, and Netatmo have connected products for this.
- Multi-zone heating with just radiator thermostats (TRVs). This is popular in Germany/DACH and Central Europe. For this heating setup, brands like Eurotronic, Aqara, Danfoss, and Fibaro have smart radiator thermostats.
- Heating (and cooling) via air conditioning. While you might think of an AC for cooling, the fact that it’s based on a heat pump makes it a pretty decent and efficient heater as well. Brands like Daikin, Panasonic, and Mitsubishi have connected ACs, and Broadlink, SwitchBot, and Tado have Infrared AC controllers.
- Electric space heaters. Brands like Mill and Adax have connected space heaters. Next, you can switch most simple space heaters on and off with a simple smart plug.
![Energy Management Connected heating Homey App Store](https://blog.athom.com/wp-content/uploads/2023/03/Screenshot-2023-03-08-at-16.39.42-2000x643.png)
- Connected appliances. Bosch, Siemens, and Miele are brands that offer these. You can schedule the start of programs with a management system like Homey.
- Smart Plugs. Add them to any mains-powered device to switch them on or off. Some feature energy measurements as well. Note that many devices require to press a ‘start’ button. For this, you could extend the plug with a SwitchBot bot, but the solution could be more elegant.
- Built-in relays. Built to switch heavy-duty gear, these built-in relays can switch any electrical product and are often invisible after installation. Note that electrical knowledge is required to install them. These are not the most user-friendly devices. They are available from a wide range of brands, including Heat-It, Fibaro, Qubino, Shelly, and more.
![Homey Best Buy Guide: Smart Plugs Featured](https://blog.athom.com/wp-content/uploads/2024/02/homey-best-buy-guide-smart-plugs-featured-1856x752-1.jpg)
![Homey Energy real-time energy management](https://blog.athom.com/wp-content/uploads/2023/03/Screenshot-2023-03-08-at-16.26.08-2000x1254.png)
Okay, we’ve covered the various factors affecting your home’s total energy consumption. So, where do we start to achieve efficient energy management in a modern home? The key lies in having a single Home Energy Management System (HEMS) in control and a compatible energy reader. To explore different energy monitoring options, check out Energy Monitoring Solutions Around the World.
Homey connects all your home’s energy solutions under one umbrella. With devices like the Homey Energy Dongle, you can gain real-time insights into your energy consumption and generation. The true power, however, lies in automation.
- Connect with as many energy solutions as possible, giving you ultimate control and freedom of choice.
- Be able to work with and automate based on dynamic tariff pricing.
- It allows you to easily automate your home based on your wishes for comfort, convenience, and energy without needing to learn code.
- Be user-friendly and accessible from anywhere in the world for monitoring and control.
- Bonus: also integrate with the rest of your smart home for a single, unified experience and even more energy savings.
While Homey is not specifically a Home Energy Management System (HEMS), it can perform all functions (and beyond) typical of HEMS. Using P1 smart meters like our Homey Energy Dongle, it receives real-time data about your home's energy usage. Further, Homey seamlessly connects and automates various smart devices from different brands and protocols, including lighting, heating, security, entertainment, and solar systems.
![](https://blog.athom.com/wp-content/uploads/2022/10/Homey-Pro-Web-App-Mobile-App-2000x1126.png)
With Homey, we set out to build a better smart home. Energy management is a core part of any smart home, and Homey already connects to over 50,000 devices from over 1,000 brands. In addition, Homey Flows and Homey Advanced Flows allow automation based on anything – from a motion sensor to your solar panel output and the energy prices of this hour. The possibilities are limited solely by your imagination and creativity.
