Energy Management in a Smart Home
Contents
Energy management factors
Several factors heavily influence how you use, pay, and manage energy in your home. Consider these factors when you select a home energy management system. Don’t stop at the factors that apply to you and your house right now. Instead, take some time to think about what factors will also play a role in the future.
  • Solar at home
  • Type of heating and cooling: city heating (hot water), gas, heat pump, or electrical/radiant
  • Availability and use of EVs
Even if you don’t know all your plans yet, it’s good practice to stay as versatile as possible with your HEMS choice. Consider one that connects with many different solutions and covers a wide range of use cases. Homey, especially Homey Pro, is an energy management powerhouse!
Solar at home
For inspiration, check out Christian Doczekal’s use case for his Growatt solar panel system. Using Homey as a HEMS, he developed a system that cools his home during the summer with over 91% of the energy generated from his solar panels!
Type of heating
Take inventory of your home’s biggest energy consumers. In addition to heating, these might include washers, dryers, dishwashers, saunas, pools, electric or induction stoves, ovens, and freezers. Some of these devices have a buffering capacity, meaning they can store energy, offering significant energy management opportunities.
EV Chargers Featured Image
Connected solar at home
  1. Get a smart and connected inverter. For instance, inverters from EnPhase, Growatt, SolarEdge, SMA, Tigo, GoodWe, and Huawei can connect to Homey Pro to communicate their energy generation to you.
  2. Get a smart meter add-on that can measure your solar generation. This is usually called a ‘3-phase meter’. Brands like Eastron and Tibber have add-ons that can do this and connect to an energy management system like Homey.
Connected heating solutions
Even though heating systems differ a lot, they are all controlled by thermostats. Nowadays, there are smart thermostats available for almost every heating setup. Ideally, you need a thermostat that your home energy management system can control for energy efficiency and savings. Homey is compatible with a wide range of thermostats for multiple heating configurations:
  1. Multi-zone heating with different thermostats. This is popular in Scandinavian countries like Norway and Sweden. Brands like Heat-it have connected room thermostats for this option.
  2. Heating with a main thermostat (either single or multi-zone). This is popular in Western Europe. Brands like Honeywell Evohome, Tado, and Netatmo have connected products for this.
  3. Multi-zone heating with just radiator thermostats (TRVs). This is popular in Germany/DACH and Central Europe. For this heating setup, brands like Eurotronic, Aqara, Danfoss, and Fibaro have smart radiator thermostats.
  4. Heating (and cooling) via air conditioning. While you might think of an AC for cooling, the fact that it’s based on a heat pump makes it a pretty decent and efficient heater as well. Brands like Daikin, Panasonic, and Mitsubishi have connected ACs, and Broadlink, SwitchBot, and Tado have Infrared AC controllers.
  5. Electric space heaters. Brands like Mill and Adax have connected space heaters. Next, you can switch most simple space heaters on and off with a simple smart plug.
  1. Connected appliances. Bosch, Siemens, and Miele are brands that offer these. You can schedule the start of programs with a management system like Homey.
  2. Smart Plugs. Add them to any mains-powered device to switch them on or off. Some feature energy measurements as well. Note that many devices require to press a ‘start’ button. For this, you could extend the plug with a SwitchBot bot, but the solution could be more elegant.
  3. Built-in relays. Built to switch heavy-duty gear, these built-in relays can switch any electrical product and are often invisible after installation. Note that electrical knowledge is required to install them. These are not the most user-friendly devices. They are available from a wide range of brands, including Heat-It, Fibaro, Qubino, Shelly, and more.
Homey Best Buy Guide: Smart Plugs Featured
Okay, we’ve covered the various factors affecting your home’s total energy consumption. So, where do we start to achieve efficient energy management in a modern home? The key lies in having a single Home Energy Management System (HEMS) in control.
Homey connects all your home’s energy solutions under one umbrella. You gain a clear overview of your home’s energy performance without navigating multiple apps. The true power, however, lies in automation.
  2. Be able to work with and automate based on dynamic tariff pricing.
  3. It allows you to easily automate your home based on your wishes for comfort, convenience, and energy without needing to learn code.
  4. Be user-friendly and accessible from anywhere in the world for monitoring and control.
While Homey is not specifically a Home Energy Management System (HEMS), it can perform all functions (and beyond) typical of HEMS. Homey seamlessly connects and automates various smart devices from different brands and protocols, including lighting, heating, security, entertainment, and solar systems.
With Homey, we set out to build a better smart home. Energy management is a core part of any smart home, and Homey already connects to over 50,000 devices from over 1,000 brands. In addition, Homey Flows and Homey Advanced Flows allow automation based on anything – from a motion sensor to your solar panel output and the energy prices of this hour. The possibilities are limited solely by your imagination and creativity.
