Discover the new Homey Portal
Control Zigbee devices with Google Home using Homey
Zigbee devices don’t connect directly to Google Home. To control Zigbee lights, plugs, or sensors with Google Home, you need a smart home hub that supports Zigbee and can make those devices available to Google’s platform.
Homey acts as that hub. It connects to Zigbee devices and exposes supported devices to Google Home. Homey stays in control of the devices and Google Home becomes an additional way to control them.
What you need
To control Zigbee devices with Google Home, you need:
Zigbee devices must always be paired with Homey first, before they are added to Google Home.
What “exposing devices” means
When Homey exposes a Zigbee device to Google Home, it means Homey shares that device with Google Home through its integration.
The device:
  • stays paired with Homey
Google Home does not communicate with Zigbee devices directly. All commands are routed through Homey.
A simple way to think about it: Homey translates Zigbee devices into controls Google Home understands.
How to connect Homey to Google Home
You don’t need to re-pair Zigbee devices or change how they’re connected.
The process works like this:
    Open the Google Home app, choose Add / Set up device, select Works with Google, choose Homey, and allow Google to access your Homey account.
    After linking, Google Home automatically imports the supported Homey devices.
After this, your Zigbee devices appear in Google Home without any additional pairing steps. The devices remain paired only with Homey.
How the connection works
    Google Home communicates with Homey through the Google Home integration, not with Zigbee devices directly.
  3. Homey forwards commands
    When you control a device in Google Home, Homey translates the command and sends it to the Zigbee device.
Once exposed, Zigbee devices usually appear in Google Home as standard smart devices, such as:
  • Switches and plugs
You can:
  • Assign devices to rooms
What to keep in mind
  • Not all Zigbee features are available in Google Home
Use Google Home for control and voice and Homey for automation and logic.
In short
Zigbee devices can’t connect directly to Google Home.
Homey exposes them by making them visible and controllable in Google Home, while keeping all Zigbee communication and advanced automation inside Homey.
Google Home becomes an additional way to interact with your devices and Homey stays in control.
