Black Friday — Save 500 kr on Homey Pro and up to 20% on everything else Discount applies automatically at checkout • While stock lasts
Discover what hardware is used around the world to monitor energy usage. Learn how smart energy readers — like the Homey Energy Dongle — can help you identify large consumers and optimize your household's energy use.
  • Discover smart energy meters used across the world
  • Learn about alternative energy monitoring solutions
  • Enable automation through smart home platforms — like Homey
What are Smart Energy Meters?
Types of Smart Energy Meters
P1 Readers
Smart P1 Port Readers
Smart Meter with a P1 Port
  • DSMR 4.x and earlier: Basic functionality with limited data updates. Provides 5V at 100 mA, insufficient to power P1-connected readers.
  • DSMR 5.x: Real-time updates with renewable energy systems support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
  • DSMR 6.x: Real-time updates with smart grid integration and advanced encryption support. Provides 5V at 250 mA, enough to power P1 readers including the Homey Energy Dongle.
Countries using P1 Readers:
  • 🇳🇱 The Netherlands
  • 🇧🇪 Belgium
  • 🇱🇺 Luxembourg
  • 🇩🇰 Denmark
  • 🇭🇺 Hungary
  • 🇸🇪 Sweden
  • 🇫🇮 Finland
  • 🇦🇹 Austria
  • 🇱🇹 Lithuania
  • 🇨🇭 Switzerland
HAN Readers
Smart HAN Energy Readers
Smart Meter with a HAN Port
Countries using HAN Readers:
  • 🇳🇴 Norway
  • 🇸🇪 Sweden
  • 🇩🇰 Denmark
  • 🇫🇮 Finland
Optical (Pulse) Readers
Utility Meter with a LED Pulse Reader
  • 🇺🇸 United States
  • 🇨🇦 Canada
  • 🇬🇧 United Kingdom
  • 🇦🇺 Australia
  • 🇯🇵 Japan
  • 🇪🇺 Most European Countries
Clamp Readers
Smart Clamp Energy Meters
Smart 3-Phase Clamp Reader
Homey Energy
