There's something special about stepping into a warm swimming pool on a sunny day. The water feels inviting, the air is calm, and everything slows down for a moment. But behind that comfort often sits a system that's anything but relaxed: manual timers, fixed schedules, and pool heaters running regardless of whether your home is producing solar energy or not.
With Homey, your swimming pool becomes part of your smart energy system. Instead of heating water whenever a timer says so, your pool can warm up when your solar panels produce excess energy, increasing self-consumption and reducing unnecessary grid usage. The result is a pool that feels just as comfortable, while working much more intelligently behind the scenes.
Why a smart swimming pool makes sense today
A swimming pool is one of the largest energy users in a home. Pool pumps, filters and heaters can draw significant power, often for several hours a day. Traditionally, these systems run on fixed schedules that don't take solar production or household consumption into account.
A smart swimming pool changes that logic.
Instead of asking, "Is it time to heat the pool?", the system asks, "Is there solar energy available right now?" When your pool reacts to energy availability rather than the clock, it naturally becomes more efficient, without sacrificing comfort.
From standalone pool equipment to an energy-aware system
Most pools already have the core components needed for smart control. Pumps, heaters and valves are usually switched electrically, either through dedicated controllers or simple relays. Homey connects to these systems and coordinates them with the rest of your home.
Once connected, your pool stops being a standalone installation. It becomes part of your wider energy flows, responding to solar production, household usage and time of day, all within one system.
Heating with solar surplus, on your terms
One of the most practical use cases for smart pool automation is solar surplus heating. When your solar panels produce more energy than your home is using, that excess energy is often exported to the grid at a lower value. A swimming pool offers a natural alternative: store that energy as heat in water.
With Homey, pool heating can start automatically when:
- solar production exceeds household consumption
- other high-priority devices are idle
- energy would otherwise be exported
You can also combine energy conditions with practical boundaries. For example:
- heat the pool only between certain hours
- stop heating once a target temperature is reached
- avoid running heaters during peak household usage
A smart swimming pool isn't about running equipment more often. It's about running it at the right moment. The pool warms up during the day, when solar energy is abundant, and retains that heat for later use. This increases self-consumption without requiring constant monitoring or manual switching.
Pump, filtration and monitoring that adapt automatically
Pool pumps and filtration systems often run on fixed daily schedules. While effective, this approach ignores what's happening elsewhere in the home. With Homey, filtration can adapt to:
- solar availability
- time of day
- overall energy load
On sunny days, filtration can run longer using solar energy. On cloudy days, it can scale back automatically. The water stays clean, while energy use stays aligned with production.
Most pool systems come with basic status indicators or control timers. These are useful, but they don't always lead to better decisions. Homey Energy brings pool usage, solar production and household consumption together in one overview. Instead of checking multiple apps, you see how everything interacts, and automation takes care of the response. Monitoring becomes a background tool, not a daily task.
Safety first, fitted naturally into your smart home
Pool equipment combines water, electricity and heat, so reliability matters. A smart swimming pool should feel safe before it feels clever. Homey doesn't replace existing safety systems. All built-in protections in pumps and heaters remain fully active. Homey simply adds an extra layer of awareness.
For example, Homey can:
- stop heating after a maximum runtime
- alert you if equipment runs unexpectedly long
- ensure pumps don't start outside defined conditions
This adds peace of mind without increasing complexity.
What makes a smart swimming pool truly valuable is how naturally it fits into the rest of your home. When pool heating starts, Homey can:
- reduce other heavy loads temporarily
- coordinate with EV charging or heat pumps
- prioritise self-consumption automatically
When heating stops, the system returns to normal operation without manual intervention. Over time, the pool becomes part of your daily and seasonal rhythm, rather than a separate system you have to manage.
Growing your setup, one step at a time
You don't need to automate everything at once. Many people start by linking pool heating to solar surplus. Later, they add pump optimization, monitoring, or integration with dynamic tariffs. Homey Pro supports this gradual approach, allowing your pool automation to grow alongside your energy system.
The goal isn't maximum optimisation. It's better use of the energy you already produce.
A smart swimming pool feels less like a technical project and more like a natural extension of your home. The water is warm when it should be, energy is used when it's available, and everything switches off reliably when it's no longer needed. With Homey as the intelligent layer underneath, your pool becomes calmer, more efficient and easier to live with, without constant attention.
A pool is meant to be enjoyed. Making it smart simply ensures it works with your energy, not against it.
Conclusion: a smart pool is a more sustainable pool
A smart swimming pool transforms energy-heavy equipment into a flexible part of your home. By heating with solar surplus, adapting pump schedules and automating safely, you increase self-consumption and reduce unnecessary energy export.
With Homey, your pool stops being a fixed load and becomes an energy-aware system, warm when you need it, efficient when you don't.
Once you experience it, fixed timers feel strangely outdated.
Can every swimming pool be made smart with Homey?
Many pools can be automated using existing pumps, heaters and external relays. Electrical safety and compatibility should always be checked by a professional installer.
Can Homey heat my pool automatically using solar energy?
Yes. Homey can start pool heating when solar production exceeds household consumption.
Do I need a special solar pool heater?
No. Homey works with electric heaters, heat pumps and other systems that can be switched or controlled safely.
Will my pool still work if the internet is down?
Yes. Homey Pro runs automations locally. Only cloud-based notifications may be temporarily unavailable.
Can Homey prevent over-heating the pool?
Yes. You can define target temperatures and maximum runtimes.
Can pool pumps run only on solar energy?
They can be prioritised during solar production while still meeting hygiene requirements.
Does this increase wear on my equipment?
Automation focuses on smarter timing, not excessive switching. Equipment runs when conditions are optimal.
Can I combine pool automation with dynamic tariffs?
Yes. Homey can include price signals alongside solar production.
Do I need Homey Pro specifically?
Advanced local automation and energy-based logic require Homey Pro.
Can I expand this later?
Yes. Pool automation can grow step by step alongside your smart energy system.
Smart swimming pool
A pool where pumps, heaters and controls react automatically to conditions such as energy availability.
Solar self-consumption
Using solar energy directly in your home instead of exporting it to the grid.
Pool heat pump
An efficient heating system that transfers heat into pool water using electricity.
Solar surplus
Excess solar energy produced beyond household consumption.
Pool filtration
The process of circulating and cleaning pool water to maintain quality.
Automation
Rules that allow systems to react automatically without manual control.
Homey Pro
The local smart home hub that connects devices, energy data and automation.
Energy-aware control
Control logic that reacts to production, consumption and availability.
Local automation
Automations that run inside Homey Pro, even without internet access.
Smart energy system
A home setup where generation, consumption and devices work together intelligently.
