Discover the new Homey Portal
 I live in a shared apartment building. The front-door of the complex is normally opened by my key, or when someone dials my house number I can open the door remotely when I'm at home.
One day however I figured out that the intercom system in my apartment can open the door remotely - even when no one ringed my apartment's number! Obviously this had to be connected to Homey.
Project requirements
  • Homey
  • Intercom with a physical button
  • Wemos D1 Mini (link)
  • Wemos Relay shield (link)
  • 5V Micro-usb power supply
  • Two jump wires
  • Basic soldering skills
My intercom has a push button that -when pressed- connects two contacts, which then opens the door. One way to connect two wires automatically is by using a relay. The relay is switched on and off by the Wemos D1 module, a Wi-Fi enabled prototype board based on the ESP8266 chip. Homey sends a signal to the Wemos D1 - but first let's connect the electronics.
Wiring the electronics
Connect the two wires to the NO (Normally Open) and the C (Common, in the middle) contacts. The button will now not make any connection unless instructed to do so. For more information about how relays work, Instructables has made a great background article about relays.
Flashing the firmware
The Wemos D1 Mini is a microcontroller, and needs some firmware to run. Install the Arduino software as described in this tutorial.
The software I've written (named RelayCtrl)is nothing more than a webserver with a /toggle endpoint, which quickly toggles the relay on, waits 500ms, and turns the relay off again.
Download the source code from my GitHub repository and flash it on the Wemos D1 Mini from a PC. After flashing, connect to the Wi-Fi network named RelayCtrl. Follow the instructions to connect the module to your Wi-Fi network.
To test the system, navigate to http://relayctrl.local/toggle in your browser. Upon visit, you should hear the relay briefly click on and off.
Connecting to Homey
I've used the following apps on Homey:
All three are made by our amazing community. Thank you for these very helpful apps!
Next, I've created two Flows. The first Flow actually toggles the relay by sending a HTTP GET request, just like we did in the browser.
The second Flow starts this Flow when the virtual device's button has been pressed:
Adding an Android widget
Opening the Homey app can take a few seconds. While we're working on a new version of the app which is a lot faster, I'm too impatient and created my own solution.
So I've added a third Flow:
When a Webhook is received (this is an URL accessible from anywhere in the world), the intercom is also opened. Next, I've downloaded the HTTP Widget app from the Google Play Store on my Android phone. Simply add a widget to your homescreen, copy-paste the webhook URL from Settings → Webhook Manager in Homey and replace your_event_name with intercom and paste it in the widget. My URL looked like this: `https://webhooks.athom.com/webhook/57274085acb3bd6d24b3d200/?token=mytokenhere&event=intercom&data1=a&data2=b&data3=c`
Future improvements
— Emile
