KNX RF: Using Wireless KNX in Homey
When people think of KNX, they picture twisted pair bus cable and dense wiring diagrams. But KNX also has a wireless variant: KNX RF, operating at 868.3 MHz in Europe.
KNX RF follows the same logical model as KNX TP. Devices send and receive standard KNX telegrams, use the same group addresses and datapoint types and connect to twisted pair segments via RF media couplers. From a logical perspective, a KNX RF device behaves exactly like a wired KNX device. It just uses radio instead of copper.
Why KNX RF Exists
KNX RF solves a very practical problem: not everything can be wired easily. The most common scenarios are retrofitting KNX push buttons into existing walls without chasing new bus cables, adding window contacts or sensors where cabling is difficult and extending a KNX installation into adjacent spaces where pulling twisted pair is not worth the effort.
Instead of abandoning KNX in those areas, you add a KNX RF line, connect it to the TP backbone via a media coupler and keep one consistent logical system throughout the building.
RF Characteristics at 868 MHz
KNX RF uses 868.3 MHz with FSK modulation and a data rate of around 16 kbit/s. That combination gives it better wall penetration than 2.4 GHz systems, a range well suited to typical homes and small buildings and short efficient telegrams similar to those on twisted pair, just transmitted over the air. The design follows European short-range device regulations, keeping transmit power and duty cycle within well-defined limits.
Media Couplers: The Bridge Between TP and RF
The key hardware element in a KNX RF setup is the TP/RF media coupler. It listens on the TP bus for relevant group addresses and forwards them into the RF domain. It also listens on the RF side and passes incoming RF telegrams back onto the TP bus where appropriate.
From Homey's perspective, all of this is invisible. Homey sees a unified KNX system through the IP gateway. Whether a device sits on a twisted pair line or communicates over RF makes no difference. It still appears as a KNX device with its capabilities intact.
KNX RF vs Zigbee, Z-Wave and Thread in a Homey System
Homey already speaks Zigbee, Z-Wave, 433 MHz, Bluetooth, Wi-Fi and can integrate Matter and Thread devices. So where does KNX RF fit alongside all of that?
The distinction comes down to integration level. KNX RF devices participate in the KNX installation as full citizens, using group addresses and datapoint types. They are the right choice when you want wireless devices that behave as if they were wired into the KNX project. Zigbee, Z-Wave and Thread devices operate through their own stacks and cover the broad range of consumer products that Homey already handles well.
In short, use KNX RF to extend KNX's infrastructure-grade behaviour into areas where cabling is not possible. Use other radios for the consumer ecosystem that surrounds it.
Security: KNX RF with Data Secure
KNX RF can also participate in KNX Data Secure. Secure-capable RF devices encrypt and authenticate their telegrams, making eavesdropping and replay attacks significantly harder. This matters most when KNX RF covers security-sensitive functions like window contacts, motion detection or access-related control. Combined with a secure TP backbone and a properly configured KNX IP Secure gateway, you can maintain a consistent security story across both wired and wireless KNX segments.
Complement, Not Competition
In a Homey-powered smart home, the different radios each have a natural role. KNX RF handles wireless that behaves like KNX: standardized, tightly integrated into the KNX project and consistent with the rest of the installation. Zigbee, Z-Wave and Thread cover the broad range of consumer smart devices including bulbs, plugs, sensors, locks and remotes. Wi-Fi and Bluetooth serve high-bandwidth or short-range devices like cameras, speakers and other connected hardware.
Because Homey speaks all of these protocols, you choose technology per device based on installation constraints, performance needs and product availability rather than because you are locked into a single radio.
Use KNX RF Where KNX Needs to Go Wireless
KNX RF is not meant to replace Zigbee or Z-Wave. It exists to avoid a false choice between all wired and all wireless. If you already have KNX, it is the natural option when you need to extend the installation into places where bus cabling is difficult and you want those wireless devices to behave like native KNX participants.
Homey sits above all of it, merging KNX TP, KNX RF and every other radio into one coherent smart home. That gives you the freedom to use the right technology in every corner of the building without ending up with separate systems running in parallel.
Is KNX RF range comparable to Zigbee?
In many buildings the range is comparable or even better per hop due to 868 MHz propagation. This lower frequency often penetrates walls more effectively than the 2.4 GHz signal used by Zigbee. Actual performance always depends on your specific building materials and layout.
Do KNX RF devices need batteries?
Many sensors and wall transmitters require batteries to operate. Some specialized products use energy harvesting technologies to function without them. You should check the specific hardware requirements for every device you plan to install.
Can I retrofit KNX RF into an existing KNX TP installation?
Yes. You can add a media coupler to make your installation radio capable without changing any existing wiring. This allows you to place new switches or sensors in locations where running a physical cable is impossible.
How does KNX RF compare to 433 MHz devices?
KNX RF is a standardized and bidirectional medium with advanced security options. Many consumer 433 MHz devices are basic and proprietary. [!!!] Choosing the standardized option provides much better long term interoperability for a professional home.
Can KNX RF coexist with other 868 MHz devices?
Yes. It operates within standard regulatory limits for that frequency band. You may need careful spectrum planning in very dense environments to avoid potential congestion from other smart home hardware.
Does KNX Data Secure work over RF as well?
Yes. Data Secure can protect telegrams on both twisted pair and radio media if the devices support it. This adds an essential layer of encryption and authentication to your wireless communication.
Is KNX RF required for a modern KNX home?
No. It is an optional tool for specific extension scenarios. Many modern homes remain purely twisted pair because the reliability of a physical wire is still the primary goal for most professional installations.
KNX RF
KNX RF is a radio-based medium operating at 868.3 MHz in Europe. It uses short and low-rate telegrams specifically designed for reliable building automation. This allows wireless devices to join the network without the need for additional data cabling.
Media Coupler
A media coupler is the device that connects different physical layers like twisted pair and radio. It forwards telegrams between these segments while strictly respecting KNX addressing and filtering rules. [!!!] Proper configuration of the filter table is essential to prevent unnecessary traffic from congesting the wireless bandwidth.
868 MHz Band
The 868 MHz band is a European ISM frequency range used by KNX RF and other short-range hardware. It offers superior building penetration compared to higher frequencies like 2.4 GHz. This makes it a very effective choice for residential smart home infrastructure where walls are thick.
FSK Modulation
Frequency Shift Keying is the specific modulation technique used by KNX RF to encode data. It works by shifting the carrier frequency to represent different logical bits. This method provides a robust signal that is resistant to common environmental noise in the home.
RF Line
An RF line is a logical segment of a KNX installation that uses radio as its physical medium. It functions exactly like a traditional twisted pair line within the software topology. This allows you to manage wireless zones with the same professional tools used for wired segments.
Integrated System
An integrated system unifies wired KNX and various wireless technologies through a platform like Homey. This approach provides a single view and a unified automation engine for the entire property. It bridges the gap between industrial-grade reliability and modern consumer electronics.
Backbone (KNX IP)
The IP-based backbone acts as the high-speed core of a modern KNX installation. It links multiple lines and areas regardless of whether the field segments use physical wires or radio. [!!!] Using an IP backbone is the most scalable way to connect complex multi-story systems to a central hub.
