HomeWizard switch to Homey
Published 3 years ago 7 minutes
homey
By switching from HomeWizard to Homey you can get much more out of your home. So you can now for example, let your TV be a part of your automation with Homey’s infrared. Do you want to expand? Then you have much more choice of brands and products, both in the more expensive and cheap segment. Automating via Homey is simpler and more versatile than in HomeWizard with Homey Flow.
Connectivity
homey
This means that Homey’s technology can connect via the same frequencies as HomeWizard can, and adds many more. Zigbee and Z-Wave in particular are important here, because most new wireless Smart Home products are provided with these technologies. 433MHz is mainly used by older and cheaper products, and has a number of disadvantages such as one-way traffic and the lack of so-called mesh technology.
Integrations
You don’t have a smart thermostat but already have a HomeWizard HeatLink? Then you have two options. Either you keep your current HeatLink and Homewizard, and connect it with Homey. In this case you unfortunately can’t replace your HomeWizard, because Homey is not able to connect directly to the HeatLink. Do you want to phase out HomeWizard completely? Then we advise you to buy a smart thermostat.
Homey generally supports all 433MHz devices that HomeWizard also supports – and more. Consider, for example, Somfy RTS and Brel engines, or devices from KlikAanKlikUit and Smartwares. Homey adds a lot of Zigbee and Z-Wave devices, which can’t be controlled through HomeWizard. You can think of IKEA lights, Xiaomi Aqara devices or reliable sensors with Z-Wave technology, like Fibaro or Aeotec.
homey
Homey’s main downside in this area is the products from Smartwares PRO and HomeWizard itself, like the HeatLink and EnergyLink. Because these products are made by Smartwares / HomeWizard themselves, they only work with HomeWizard, and with nothing or nobody else.
However, through the open platform of Homey there is even support for HomeWizard available in Homey. So if you have a lot of Smartwares PRO or HomeWizard devices, you can still enjoy Homey through this integration. However, you still need your HomeWizard. In this case you can’t completely replace it.
Platform
Another big difference between the two systems are their structure and platform. On HomeWizard, you can’t add your own apps or modules, it is a closed system. Only additions that HomeWizard itself publishes can be used. And that does not happen anymore: the electronics in HomeWizard are not very powerful and the memory of the device is already full. There is therefore no future development for the product.
homey
Future
One of the most important differences is the direction / development of the platform. As described above, HomeWizard is no longer updated because it’s simply not possible. Parent company SmartWares is phasing out HomeWizard in favor of their SmartSwitch and the Link, products that are more limited. Homey on the other hand, with its open platform, only becomes more versatile. For example, integrations are added almost daily, varying from lighting or security to education, fun, comfort or energy efficiency.
If you do not have these products, then it’s time for something new. Replace your HomeWizard with Homey and catapult your home into the future. Use the same products as now, add your TV directly to your installation, and expand with Sonos, IKEA lighting, Chromecast, Z-Wave devices and more. Discover Homey.
Subscribe to our newsletter and be on top-of-mind about new Homey features, exclusive offers and more.
