Door/window sensor, contact sensor, call them whatever you like. They are compact devices filled with functionality, mainly intended to monitor doors and windows. However, with a bit of creativity it can achieve much more than that. Here are a few ideas to help you get started using these sensors to make your home a little smarter.
A Contact Sensor in your home
Fight the draft
Practically every home has one of these: a door that's never closed. Whether it's a construction issue, a broken hinge or a forgetful family member, an open door allows draft and cold to come in. Keep an eye on that specific door with a contact sensor that reports directly to the Homey Smartphone App.
You can do this by pairing the sensor to Homey, and it'll immediately show up in the Homey Smartphone App interface. You can even send a push notification to your phone to notify you if the door is open. Or, even better: install the Soundboard App onto Homey and play an alarming sound when somebody doesn't close the door properly!
Sensing temperature
Create somewhat advanced Flows with temperature changes. Set your extreme temperatures and adjust your thermostat according to the measured temperatures. Of course, this will require additional devices, like a smart thermostat or radiator valves.
Monitoring your windows
Home Security
Place sensors on the entrances of your house - ideally any that could be accessible to someone trying to break in, but at the very least the front- and backdoor. Depending on your home, it might make sense to tweak your set-up for the various different sensors, such as a motion sensor.
Get notified of new mail
Beer fridge
Not all sensors have to be used in a sensible, intelligent way. Have some fun with them! Add a contact sensor to the beer fridge in your mancave. Install the Homey Soundboard App and pick a cool sound that plays when you open the fridge. The next time you get up during guy's night to get beers from the fridge, your friends will be notified by the sound!
