đź–¤ Save C$69 on Homey Pro and 12.5% on everything else with code BLACKFRIDAY24
A Contact Sensor in your home
a contact sensor in a home
Fight the draft
Sensing temperature
Monitoring your windows
Home Security
Get notified of new mail
Beer fridge
