Control Zigbee devices via Matter with Homey
Zigbee devices don’t support Matter directly. To control Zigbee lights, plugs, or sensors on Matter-based platforms, you need a smart home hub that can translate between Zigbee and Matter.
Homey acts as that bridge, exposing Zigbee devices to other ecosystems over Matter. Homey stays in control of the Zigbee devices and Matter-based platforms gain access to them through Homey.
What you need
To control Zigbee devices via Matter, you need:
Zigbee devices must always be paired with Homey first, before they can connect with Matter.
What “exposing devices” means
When Homey exposes a Zigbee device to Matter, it means Homey shares that device with Matter in a simplified, standardised form.
The device:
  • stays paired with Homey
  • becomes available to Matter-based platforms
Matter controllers communicate with Homey (as a Matter Bridge), and Homey controls Zigbee devices locally. A simple way to think about it is that Homey translates Zigbee devices into Matter-compatible devices.
How to expose Zigbee devices to Matter with Homey
Exposing devices to Matter is managed from within Homey. You don’t need to re-pair devices or change how they’re connected.
The process works like this:
  2. Open the Matter Bridge settings in Homey
    After installing the Matter Bridge app, open its settings:
    • In the Homey app (iOS / Android): go to More (⋯) → Settings → Matter Bridge
    • In the Homey Web App: go to Settings (⚙︎) → Matter Bridge → Configure
    • Add Homey as a Matter Bridge
      From your Matter controller’s app (such as Apple Home or Google Home), add a new Matter device and scan the QR code shown in Homey.
    • Choose which devices to bridge
      During setup, select which Homey devices you want to expose via Matter. Only the devices you choose will be shared.
After this, the selected devices appear in your Matter platform. They remain paired with Homey, and no additional pairing steps are required.
How the connection works
  2. Matter platforms connect to Homey
    The Matter platform communicates with Homey, not with Zigbee devices directly.
  3. Homey forwards commands
    When you control a device through Matter, Homey translates the command and sends it to the Zigbee device.
What you can do via Matter
Once exposed, Zigbee devices appear in Matter-based platforms as standard Matter device types, depending on how the device is mapped in Homey and supported by the Matter Bridge.
  • On/Off Lights, Dimmable Lights, Color Lights & Temperature Lights
  • Plug-in Sockets
  • Thermostats
  • Locks
  • Blinds, Curtains, Roller Shutters
  • Door/Window Sensors
  • Temperature & Humidity Sensors
  • Motion & Occupancy Sensors
  • Air Quality Sensors
  • CO2 & Smoke Alarms
You can:
  • Control devices in your Matter platform app
  • Use voice assistants connected to Matter
  • Include devices in Matter-based automations
What to keep in mind
A few important points:
  • Matter exposes a standardised feature set, not every Zigbee capability is available
  • Removing a device from Homey also removes it from Matter
Use Matter for cross-platform control and compatibility and Homey for automation and device logic.
In short
Homey exposes them by translating Zigbee devices into Matter-compatible devices, while keeping all Zigbee communication and advanced automation inside Homey.
Matter becomes a universal way to access your devices across platforms and Homey stays in control.
