Discover the new Homey Portal
Blog Behind the Magic
Behind the Magic
Hardware
  2. 4 GB eMMC Flash
  3. Power Supply
  4. RGB LED (24x)
  5. Microphones (2x)
  6. Audio Chip
  7. 433 MHz
  8. 868 MHz
  9. Z-Wave
  10. ZigBee
  12. Infrared LED (6x)
  13. Infrared receiver
MicroSOM
Microcontroller
Audio
Software
console
Wi-Fi Recovery
Homey Core
Apps
profiling
Devices
Cloud
My Athom
App Store
API
Setup
Speech to Text
Firmware
Notifications
Webhooks
Callback
Other services
