Smart Plugs
Find the best smart plugs for your smart home
Whether you’re looking to control lighting, manage appliances remotely, or improve energy efficiency, smart plugs are an easy and straightforward way to get the most out of your Homey-powered smart home.
However, choosing the right smart plug can be confusing and overwhelming, especially for novice users. That’s why we’ve researched it for you, hoping to simplify and clarify things.
This Best Buy Guide explores the best smart plugs compatible with Homey. We selected these smart plugs based on their reliability, ease of use, features, and positive user feedback.
Choosing the Right Smart Plug
When choosing smart plugs for Homey, there are a few key points to consider and differentiate between. Depending on your intent and purposes, you might need one model more than another. Here are some key factors to consider when choosing a smart plug.
Maximum Power Rating
A plug with a lower max current (10 A) is acceptable for simpler things like lights and small devices. However, if you control high-power appliances like dishwashers, you will usually need a plug capable of handling inductive loads (16 A).
Energy Monitoring
Decide whether you need to keep track of the energy consumption of connected devices and appliances.
Size and Shape
Smart plugs come in various shapes and sizes. Carefully consider the dimensions and form of each to avoid issues like covering adjacent outlets.
Price
Smart plugs save you money in the long run, but deploying many can quickly add up. When deciding, consider the price-to-features correlation introduced in this Best Buy Guide.
| Brand | Model | Protocol | Maximum Load | Energy Monitoring | Price |
| Smart Plug | Zigbee | 10 A, 2300 W | ![]() | €29.99 | |
| Smart Plug | Thread | 11 A, 2500 W | ![]() | €39.95 | |
| Wall Plug | Z-Wave | 11 A, 2500 W | ![]() | €59.95 | |
| Smart Plug Mini 2 | Zigbee | 16 A, 3840 W | ![]() | €38.95 | |
| GRILLPLATS Plug | Thread | 16 A, 3680 W | ![]() | €9.99 | |
| Smart Plug | Zigbee | 16 A, 3680 W | ![]() | €24.99 | |
| Smart Plug Mini | Matter | 16 A, 3680 W | ![]() | €19.99 | |
| A1Z Smart Plug | Zigbee | 16 A, 3680 W | ![]() | €19.75 | |
| Hue Smart Plug | Zigbee | 10 A, 2300 W | ![]() | €34.99 | |
| Outdoor Plug | Z-Wave | 16 A, 3500 W | ![]() | €55.00 | |
| Plug S MTR Gen3 | Matter | 12 A, 2500 W | ![]() | €24.08 | |
| Smart Plug E2 | Zigbee | 16 A, 3680 W | ![]() | €13.99 | |
| Tapo Smart Plug | Matter | 16 A, 3680 W | ![]() | €24.90 |
Aqara Smart Plug
- Energy monitoring
- Zigbee router
- Overload protection
- Flame-retardant body
- Bulky
If you are looking for a capable Zigbee smart plug with power monitoring, the SP-EUC01 model from Aqara is a great pick. Rated at 2300 W, it can control anything you attach within its rated limit. If you exceed the max current rating, the plug has overloading and overheating protection mechanisms, automatically turning off the smart plug before anything dangerous happens.
Once connected to Homey, the Aqara wall plug will act as a Zigbee router and relay traffic from adjacent devices back to Homey Bridge, Homey Pro and Homey Pro mini—solidifying and extending your mesh network.
The Aqara model is a bit larger and bulkier than other brands, and although it won’t obstruct neighboring outlets, this is an important factor to consider when making your choice.
Eve Energy Smart Plug
- Matter smart plug
- Thread router
- Fast response times
- Pricy
The Eve Energy Smart Plug is part of the next generation of smart home devices, which leverage the latest Matter standard and Thread communication protocol to enhance your smart home experience.
Even though Thread is still very young, the Eve Energy smart plug is fully compatible with Homey Pro and Homey Pro mini. As an FTD (Full Thread Device), this plug acts as a repeater in your Thread network, relaying traffic from battery-powered end devices like motion, door and window, or temperature and humidity sensors back to Homey.
The plug can control various devices, from night lamps to coffee makers. If the power draw exceeds 11 A or 2500 W, a built-in fuse turns off the relay, safeguarding the plug and the connected appliance.
The Eve Energy Smart plug also supports energy monitoring, so you can always get an overview of the power draw and create flows based on the reading. It's worth noting that the Eve Energy is pricier than most Matter smart plugs highlighted on this list.
Fibaro Wall Plug
- Energy monitoring
- Z-Wave router
- High-quality build
- LED load indicator
- Expensive
If you prefer using Z-Wave devices, the Fibaro wall plugs are great for strengthening your network stability and overall health. Fibaro is a well-known, top-tier Poland brand that uses the Z-Wave communication protocol for most of its products.
The Fibaro Wall Plug supports a maximum load of 2500 W or 11 A, enough to connect most domestic appliances. An overload protection switch turns off the plug when it exceeds the maximum current rating.
This premium plug also supports power monitoring, giving you an overview of the connected device’s energy consumption. A built-in LED ring indicates the current load and operating mode value. You can even control this visually appealing set of LED lights from a Flow. The only real drawback of Fibaro wall plugs is their price tag—definitely more than other comparable models.
frient Smart Plug Mini 2
- Energy monitoring
- Zigbee router
- Very small
- High-power rating
- Pricey
frient Smart Plugs are among the best Zigbee smart plugs for any smart home. Their compact design makes them stand out from similar plugs. The Smart Plug Mini 2, in particular, measures only 41 millimeters in diameter, making it the smallest smart plug in our Best Buy Guide.
Despite its small size, the Mini 2 can handle a maximum load of up to 16 A or 3680 W. This means it’s suitable for connecting minor gadgets and major appliances—such as dishwashers, tumble dryers, and washing machines.
The frient Smart Plug Mini 2 also has a power meter, which tracks the consumption of whatever you decide to connect. If your appliance draws more power than the plug can handle, a built-in overload protection mechanism immediately turns off the plug. This model costs a bit more than similar plugs, but its feature set and miniscule footprint justify its price.
IKEA GRILLPLATS Plug
- Very affordable
- Energy monitoring
- Thread router
If you want the most affordable entry into the new Matter standard, the new IKEA GRILLPLATS plug is the device to go for. This model is part of IKEA’s pivot away from Zigbee, offering future-proof solutions that integrates directly with Homey Pro and Homey Pro mini via Matter.
The key differentiator here is the Thread communication protocol. Instead of relaying standard Zigbee traffic, this plug acts as a router in your Thread mesh network. To use it, you will need a Thread Border Router—a role your Homey Pro and Homey Pro mini fills perfectly.
While it replaces the older Zigbee-based INSPELNING and TRETAKT models, it maintains the robust 16 A / 3680 W power rating typical of IKEA's lineup, making it suitable for both small gadgets and larger household appliances.
Priced aggressively at around €9.99, the GRILLPLATS is positioned as a mass-adoption device. Unlike many budget plugs, it retains energy monitoring, allowing you to track the consumption of connected lamps or appliances directly within Homey. While IKEA's new Thread range is scheduled for release in January of 2026, Homey Pro already supports each product in the line-up.
Innr Smart Plug
- Energy monitoring
- Zigbee router
- High power rating
- Larger than most
Innr is another reputable brand that produces high-quality Zigbee smart devices. Of their range of smart plugs, we’ve chosen the SP 240 model as a top pick for several reasons.
This model can handle loads of up to 16 A and accurately measures the energy consumption of whatever gadget you plug in. It integrates well with Homey Bridge and Homey Pro, pushing its power monitoring data over Zigbee to your hub.
Further, the device acts as a Zigbee router, improving your network’s overall performance and stability. Measuring 52 x 52 x 82 millimeters, it’s not the smallest smart plug on our list, but it will not cover adjacent outlets.
Innr also produces an IP44-rated, waterproof 10 A outdoor smart plug, model OSP 210. This plug uses Zigbee and works with your Homey Bridge or Homey Pro.
Meross Matter Smart Plug
- Matter smart plug
- Very affordable
- High power rating
- Questionable build quality
The Meross Smart Plug model MSS315 is a Matter-enabled wall plug designed for easy use and simple smart home integration. It uses Wi-Fi as the underlying communication protocol, although your mobile device initiates the onboarding process for your Homey Pro through Bluetooth.
Rated at 16 A or 3680 W, the Meross Smart Plug can control high-power appliances without issues. The pairing button doubles as a status indicator, changing color depending on the current load.
The Meross Smart Plugs are quite affordable, considering they support Matter, going around for €19 each. While their build quality is decent, it does not rank among the highest in this list.
Nous A1Z Smart Plug
- Affordable
- Energy monitoring
- Zigbee router
- High power rating
- Some features require hub
The Nous A1Z is a Zigbee 3.0 smart plug designed to provide reliable and local control of connected devices in your smart home. With a maximum load capacity of 16 A peak and 15 A continuous, it's suitable for various household appliances, such as lamps, fans, kitchen appliances, and others.
The Nous A1Z has various safety features. A built-in overload protection mode prevents potential electrical hazards, while a child lock mode prevents children from tampering with the plug. At 46 millimeters in diameter, it’s among the smallest Zigbee smart plugs.
Once the plug is integrated into Homey through Homey Bridge or Homey Pro, you can remotely control it and monitor energy consumption. Interestingly, you can also reset the energy meter through Homey when needed. However, it’s worth noting that some features, like configuring the power-on behavior, require a Nous gateway.
Philips Hue Wall Plug
- Zigbee router
- High power rating
- Reliable
- No energy monitoring
- Low current rating for the price
The latest Philips Hue Wall Plug model can communicate using Bluetooth and Zigbee. Although it can be controlled through the Hue Bridge, using Zigbee directly is recommended for your Homey ecosystem for reliability and mesh networking purposes.
Philips Hue smart plugs are fully supported in Homey and Homey Pro and are considered a quality pick among enthusiasts. The Hue wall plugs can control various devices within their 10 A current limit, such as lamps, speakers, or other small to medium-sized appliances.
Their square-ish shape matches the standard EU sockets’ design, making these smart plugs fit together seamlessly.
POPP Outdoor Plug
- High-power rating
- Energy monitoring
- Z-Wave router
- Weather resistant
- Bulky
- Expensive
If you need a high-power, weather-resistant smart plug for outdoor use, consider the POPP 3500 W model. It uses Z-Wave to communicate with Homey Bridge or Homey Pro and acts as a network router, relaying network traffic from nearby devices.
The POPP Outdoor Plug is IP44-rated and can withstand dry and humid conditions and water splashes from any direction. Its protective lid covers the plug when it’s not in use. If you have an outdoor pool with a pump that you want to control, this plug is a perfect choice.
It also has a built-in energy meter, which provides insight into the power consumption of the connected device. An indicator LED mounted on the front lets you glance at the plug’s current status from a distance.
Once integrated into Homey, you can toggle the smart plug, monitor the energy usage, and remotely reset the total consumption the plug has recorded. The button mounted on the front can also be used for toggling, retaining the manual control of this wall plug.
Although designed for outdoor use, the POPP Outdoor Plug is quite large. Measuring 152 x 60 millimeters in height and width and 114 millimeters deep, it is bulky and unsuitable for some applications. Its high power rating and weather resistance significantly raise its price, making it one of the more expensive plugs on our list.
Shelly Plug S MTR Gen3
- Affordable
- Compact
- Advanced scripting not available over Matter
If you want a versatile, future-proof smart plug that doesn't require a dedicated hub, the Shelly Plug S Gen3 is an excellent choice. This third-generation model introduces Matter support, allowing for seamless local control and easy integration into your existing Homey ecosystem over Wi-Fi.
The Plug S MTR Gen3 is rated for a maximum load of 12 A or 2500 W. While this is lower than the 16 A standard found in some heavy-duty plugs, it is perfectly adequate for controlling lighting, entertainment centers, and most standard household appliances. A comprehensive suite of safety features, including protection against overvoltage, overcurrent, overpower, and overheating, ensures the plug turns off immediately if any limits are exceeded.
Measuring just 44 x 44 x 70 millimeters, this plug is compact enough to fit into most sockets without blocking adjacent outlets. It features a customizable LED ring that provides visual feedback on power consumption or device status, which can also be dimmed or used as a night light via a "Night mode."
The device supports real-time power monitoring, giving you precise data on your energy usage within Homey. Some Shelly scripting features may not be available over Matter, but luckily, you can develop your own advanced Flows in Homey itself.
ThirdReality Smart Plug E2
- Very affordable
- Energy monitoring
- Zigbee router
- Not suitable for inductive loads
The ThirdReality Smart Plug E2 is a cost-effective solution for those invested in a Zigbee-based smart home. This plug integrates seamlessly with Homey Bridge and Homey Pro over Zigbee, enabling remote on/off control and real-time energy monitoring of connected devices.
Rated for a maximum load of 16 A (3680 W) at 220V AC, it easily handles common household appliances and lighting. Its compact design is a key feature, preventing obstruction of adjacent outlets, a common issue with bulkier smart plugs.
For safety, the E2 includes overload protection, automatically cutting power in the event of excessive current draw. The E2’s power outage behavior can also be configured, allowing you to control how the plug behaves once it powers back up.
Once added to Homey, you can create schedules, monitor electricity consumption, and create Flows using the plug as a trigger or action. It’s worth noting that while the E2 has a maximum load of 16 A, it’s not suitable for use with inductive loads.
TP-Link Tapo Matter Smart Plug
- Matter smart plug
- High-power rating
- Affordable
- Bulky
If you have decided on a Matter-enabled smart plug, the Tapo P110M is another TP-Link model that can help you future-proof your smart home with the latest communication protocol. Homey Pro is fully compatible with Matter-enabled devices, so the P110M can be effortlessly integrated into your existing setup over Wi-Fi.
This plug is rated 16 A, so it can safely be used with high-power appliances like dishwashers, washing machines, and tumble dryers. Its rectangular shape instead of round might appeal more to specific users, but it does add bulkiness to an outlet.
The TP-Link Tapo is available in two variants, with and without energy monitoring, respectively labelled as model P100M and P110M.
Simpler Alternatives
If you’re not looking for energy monitoring or other advanced features highlighted in our top picks, a basic 433 MHz smart plug with simple on/off functionality might suit your needs. These plugs are small, barely noticeable, and usually very affordable.
We recommend considering Trust Smart Home, Telldus, Nexa, or Dio smart plugs, which all work over 433 MHz with Homey Bridge and Homey Pro.
Final Thoughts
Wrapping up our Best Buy Guide for top smart wall plugs, it’s evident that these devices are crucial for upgrading your smart home. They simplify controlling lights, managing appliances, and boosting energy efficiency in any Homey smart home. We’ve showcased various models known for their seamless integration with Homey, dependable performance, and strong user satisfaction.
When choosing a smart plug, consider the factors outlined in this guide, such as maximum power capacity, energy monitoring capability, physical size and shape, and price-to-feature ratio, to ensure you get the right plug for your needs.
Zigbee
Thread
Z-Wave
Matter
