Homey Web App Changelog
Visit the Homey Web App
v1.15.0
  • Add support for Arabic language.
  • Add new capability icons.
v1.14.7
  • Increased timeouts for memory and storage info requests.
v1.14.6
  • Fixed a visual issue for the device slider.
v1.14.5
  • Fixed an issue where it was not possible to clear insights logs entries.
v1.14.4
  • Fixed an issue where the device status was not visible in the devices table.
  • Fixed an issue where it was not possible to delete insights logs.
  • Fixed an issue where the Flow card search was missing results.
  • Fixed an issue where an unwanted error was shown on closing the device controls when a camera was open.
  • Fixed an issue where tokens were missing from the predefined logic Flow cards
  • Added percentage tooltip to device controls slider.
v1.14.3
  • Fixed an issue where updates didn't load properly for Homey Pro 2019.
  • Fixed an issue where Advanced Flow would crash on Mood cards.
  • Fixed an issue where the owner name of a Flow token was not visible.
  • Fixed an issue where the owner name of a Insights log was not visible in the tooltip of a log.
v1.14.2
  • Update locales.
v1.14.1
  • Update version check for local users feature.
v1.14.0
  • Add support for local users.
v1.13.8
  • Fixed an issue where the new variable dialog would crash.
v1.13.7
  • Update locales.
v1.13.6
  • Update locales.
v1.13.5
  • Update locales.
v1.13.4
  • Fixed an issue where some Flow cards were displayed as missing for Homey Pro 2019.
v1.13.3
  • Fixed an issue where moving a zone would not update on drag and drop.
  • Fixed an issue where is was not possible to enable/disable Advanced Flow's for Homey Pro 2019.
v1.13.2
  • Fixed an issue where the devices page would crash (cannot read .getable).
  • Fixed an issue where HomeyScript Advanced Flow card actions weren't testable for Homey Pro 2019.
  • Fixed an issue where the Flow test overlay for tags would crash.
  • Fixed an issue where invalid dates would show up on sensor hover in the device controls.
  • Fixed an issue where app search would crash on search if drivers were not present yet.
  • Fixed an issue where the Advanced Flow redo button didn't work.
  • Fixed an issue where the web app would crash on device deletion when the device timeline was open.
  • Increased diagnostics report timeout.
v1.13.1
  • Fixed an issue where no insights data was showing up for the Homey Pro 2019.
  • Fixed an issue where avatars were not showing up in the notifications timeline.
v1.13.0
  • Update from athom-api to homey-api (fixes).
v1.12.0
  • Update from athom-api to homey-api.
v1.11.35
  • Add Flow and Advanced Flow import/export in alt mode context menu's.
v1.11.34
  • Fixed an issue where emtpy sections would appear in the Flow card explorer.
v1.11.33
  • Added new device icons.
  • Added pre generated logic cards for weather and energy.
v1.11.32
  • Fixed an issue where the Flow card picker would crash.
v1.11.31
  • Update translations.
v1.11.30
v1.11.30
v1.11.29
v1.11.28
  • Added zone activity indicator to device tile.
  • Battery indicator now shows by default.
  • Fixed an issue where google translate would break the Advanced Flow editor.
v1.11.27
  • Added prefilled logic cards for numeric device tags.
v1.11.26
  • Updated node-homey-lib.
v1.11.25
v1.11.24
  • Added support for evcharger capabilities.
v1.11.23
v1.11.23
  • Add support for target temperature device indicator.
v1.11.22
  • Add support for Homey Pro mini.
v1.11.21
v1.11.20
v1.11.19
v1.11.18
v1.11.17
v1.11.16
v1.11.15
v1.11.13
v1.11.12
v1.11.11
v1.11.10
v1.11.9
  • Reduced error logging.
v1.11.8
v1.11.7
v1.11.6
v1.11.5
  • Fix korean language.
v1.11.4
v1.11.1
  • Fix alarm indicator color.
v1.11.0
v1.10.7
v1.10.6
v1.10.5
v1.10.4
  • Added support for Moods.
v1.9.77
v1.9.76
  • Added new zone icons.
v1.9.75
v1.9.74
v1.9.73
  • Added Matter pairing.
v1.9.72
v1.9.71
v1.9.70
v1.9.69
v1.9.68
v1.9.67
v1.9.66
v1.9.65
v1.9.64
v1.9.63
v1.9.62
v1.9.61
v1.9.60
v1.9.59
  • Updated translations.
v1.9.58
v1.9.57
v1.9.56
