Black Friday — Save 630 kr on Homey Pro and up to 20% on everything else Discount applies automatically at checkout • While stock lasts
Blog Behind the Magic
Behind the Magic
Post mortem API outage
Local connectivity
Problem summary
Immediate actions taken
  3. Fix bug in v8 app
Long term actions
