Post mortem API outage
![](https://blog.athom.com/wp-content/uploads/2024/03/Screenshot-2024-03-11-at-11.35.18-2000x508.png)
Local connectivity
Problem summary
- AWS drops connections (still investigating why this happens)
- No exponential back-off for reconnecting in Homey Pro
- No rate-limit on connecting Homey Proʼs
- Bug in v8 app when API server is down
Immediate actions taken
- Add exponential backoff to Homey Pro
- Add rate-limit to our connect servers
- Fix bug in v8 app
Long term actions
- Add more testcases to the mobile app for local connectivity
- Improve customer communication in case issues like this arise
