Black Friday — Save 500 kr on Homey Pro and up to 20% on everything else Discount applies automatically at checkout • While stock lasts
Blog Behind the Magic
The magical cloud behind Homey
Behind the Magic
The Cloud is a term you keep hearing nowadays: cloud services, cloud storages, iCloud, the list goes on. But what exactly is a cloud? What does it do and why does it matter what it does?
What even is a cloud?
mainframe computer
Homey's cloud
connected with the homey cloud
Having our cloud takes away the headache users would experience if they had to manually connect Homey to a router for it to be able to 'talk' to the servers, and follow complicated technical protocols in order to connect certain devices to Homey. Even though Homey is designed to be mostly independent of cloud services - Homey works 99% offline with your devices, and is fully accessible locally - our cloud makes external connections as smooth as possible.
harddrive
The result is that users can tap into the cloud for very specific commands without having to deal with the setup and maintenance of the cloud itself. Essentially, it allows users to store and access data and applications on the internet, rather than using a physical hard drive. A very large one at that.
Why not do this locally?
Speech commands are also directed through the cloud. When you talk to your Homey Smartphone App, the message is sent through the cloud to a service that transcribes speech into textual data. This is tangible information for Homey. Once transcribed its sent back to Homey, and Homey can understand the command and execute whatever it contains.
use homey smartphone app anywhere in the world
Security
cloud security
Security within security
Maintaining the Cloud
cloud computing
