![Best Buy Guide: Zigbee vs. Wi-Fi Smart Lighting](https://blog.athom.com/wp-content/uploads/2017/12/Lampenblog2.jpg)
This is the second part of Maija's comparison of smart lighting. Follow this link for part one. The views expressed here are those of the author and do not necessarily reflect those of Athom.
The protocols
Wi-Fi
The biggest difference for you, as a consumer, is that bulbs that work with Zigbee and Z-Wave need a so-called controller (or hub, bridge, gateway, they are all the same thing) to communicate with each other and your mobile phone. Bulbs that 'speak' Wi-Fi can be controlled directly. Connect them to your home Wi-Fi network and it's done: happily chat away.
Zigbee
The sockets
The colours
White dimmable bulbs
White tunable bulbs
Colour bulbs
The accessories
There you go!
Happy shopping!
Maija Vilkina writes for snillevilla.se, a leading Swedish smarthome blog. This is the second part of Maija's comparison of smart lighting. Follow this link for part one.
