The protocols
Wi-Fi
Zigbee
philips hue zigbee bridge
The sockets
The colours
White dimmable bulbs
White tunable bulbs
The coldest end of the spectrum varies more widely. From 4000K (IKEA TrĂĄdfri bulbs) to 6400K (Philips Hue), to icy 9000K (Lifx RGB bulbs), and can be really great for focused work, cleaning and other activities when you need that extra energy boost on a cloudy or plain dark day (and boy, do we have a lot of those up here in the North).
white dimmable vs. tunable zigbee lamps, by ikea trĂĄdfri
Colour bulbs
The accessories
There you go!
Happy shopping!
