                Smart Home Terms Explained - A Glossary Form A To Z
Smart Home Glossary
Browse through our glossary of smart home terms. Use the navigation below to jump to a letter. Click on a term or the ▶ icon to expand and read a detailed explanation.
# | A | B | C | D | E | F | G | H | I | J | K | L | M | N | O | P | Q | R | S | T | U | V | W | X | Y | Z
  2
    ↑ Back to A–Z
2.4 GHz — The lower-frequency Wi-Fi band that travels farther through walls and supports more devices. Homey Pro uses it for broad compatibility (learn more).
The 2.4 GHz band is a ubiquitous frequency range used for many wireless technologies, from Wi-Fi to Bluetooth to cordless phones. Its primary advantage is its wide availability and good range, allowing signals to travel further and penetrate walls more effectively than higher frequencies. This makes it ideal for general home use, where devices might be scattered throughout a house. However, its widespread use is also its main drawback; with so many devices competing for bandwidth, interference can be a significant issue, leading to slower speeds and dropped connections. Think of a busy apartment building where every resident has a 2.4 GHz Wi-Fi router and multiple connected devices – the airwaves can get quite crowded. For best practices, it's often recommended to place your Wi-Fi router in a central location, away from obstructions, and to consider using 5 GHz Wi-Fi for devices that support it, especially for activities requiring higher bandwidth like streaming or gaming. In some markets, particularly densely populated urban areas, the congestion on the 2.4 GHz band is more pronounced, making the switch to 5 GHz or even newer Wi-Fi standards like Wi-Fi 6 (which also utilizes the 5 GHz band more efficiently) increasingly important for a smooth wireless experience.
  4
    ↑ Back to A–Z
433 MHz — A legacy RF (Radio Frequency) band many older sensors and remotes still use. Homey Pro speaks 433 MHz natively—no extra bridge needed (learn more).
The 433 MHz frequency band is a common choice for short-range wireless communication, especially in consumer electronics and home automation. You'll often find it in devices like garage door openers, remote control toys, weather stations, and even some smart home sensors. Its popularity stems from its relatively low cost and the fact that it operates in an unlicensed band, meaning devices can use it without needing specific permits.
However, operating in an unlicensed band also brings challenges. The 433 MHz spectrum can be quite noisy and susceptible to interference from other devices, which can impact reliability and range. Furthermore, many simple 433 MHz devices use one-way communication; the transmitter sends a command, but it doesn't receive an acknowledgment that the signal was heard. This makes careful antenna design and error checking protocols crucial for effective communication. For example, if your smart doorbell sometimes misses a ring, it might be due to interference on the 433 MHz band. In many markets, particularly in Europe, 433 MHz is widely adopted for home automation and security systems due to its historical use and established regulatory frameworks. While it offers a simple and cost-effective solution for basic wireless needs, more demanding applications often opt for other frequencies or protocols that offer greater bandwidth or security. Best practices include ensuring clear line of sight, avoiding sources of significant electromagnetic interference, and considering a system's range limitations for optimal performance.
  5
    ↑ Back to A–Z
5 GHz — The higher-frequency Wi-Fi band offering faster speeds at shorter range. Homey Pro connects on 5 GHz when you need top performance (learn more).
5 GHz refers to a frequency band used by wireless devices, most commonly for Wi-Fi. In simple terms, it's like a specific lane on a digital highway where your internet data travels. One of the main advantages of 5 GHz Wi-Fi is its faster speeds compared to the older 2.4 GHz band, making it ideal for activities like streaming high-definition video, online gaming, or large file transfers. Think of it as a less congested, high-speed lane. However, the downside is that 5 GHz signals have a shorter range and are more easily obstructed by walls or furniture. This means you might get fantastic speeds right next to your router, but the signal could drop significantly in another room. For best practices, it's often recommended to use 5 GHz for devices that are close to your router and demand high bandwidth, like smart TVs or gaming consoles, while reserving 2.4 GHz for devices that are further away or don't require as much speed, like smart home devices. A fun fact is that while 5 GHz is faster, the "GHz" actually stands for gigahertz, which is a measure of frequency, not speed directly, but a higher frequency generally allows for more data to be transmitted. In densely populated areas, 5 GHz is becoming increasingly relevant as the 2.4 GHz band often gets crowded with many networks competing for space, leading to slower speeds for everyone.
