![Raspberry Pi automation or Homey? Compare Domoticz, Home Assistant and Homey](https://blog.athom.com/wp-content/uploads/2019/10/smart-home-2.jpg)
![](https://blog.athom.com/wp-content/uploads/2021/01/DSCF5116-1024x683-1.jpg)
![](https://blog.athom.com/wp-content/uploads/2020/05/domoticz-HA-Homey.jpg)
Pricing
Homey | Raspberry Pi- based Domoticz, Home Assistant | |
Base Price | € 299 | € 65 1 |
Wireless technologies | ||
Z-Wave Plus | ✔️ included | + € 50 2 |
Zigbee | ✔️ included | + € 50 3 |
Wi-Fi | ✔️ included | ✔️ included |
Bluetooth Low Energy | ✔️ included | ✔️ included |
433 MHz - Trust / DIO | ✔️ included | + € 100 4 |
433MHz - Somfy | ✔️ included | + € 100 4 |
Infrared | ✔️ included | + € 30 5 |
KNX-IP | ✔️ included | + advanced configuration |
Out of the box cloud services | ✔️ included | + $5 /month (HA) ❌ (Domoticz) |
4 RFXcom setup
5 Broadlink RM 3 Mini
![Raspberry Pi Automation kit or Homey - Domoticz, Home Assistant OpenHAB](https://blog.athom.com/wp-content/uploads/2020/05/Raspberry-Pi-automation-vs-Homey-no-equal-2000x833.jpg)
Capabilities
![Homey-supported brands 2020](https://blog.athom.com/wp-content/uploads/2020/05/image-1-2000x798.png)
![Home Assistant Spotify Connect integration](https://blog.athom.com/wp-content/uploads/2020/05/image-2.png)
Home automation in Domoticz
![Raspberry pi automation with Home Assistant](https://blog.athom.com/wp-content/uploads/2020/05/image.png)
Home automation in Homey
![Homey Flow mac iphone web mobile](https://blog.athom.com/wp-content/uploads/2020/05/Homey-Flow-2000x1242.jpg)
![](https://blog.athom.com/wp-content/uploads/2020/01/homey-app-1.png)
Flexibility and maintenance
- Remote access to your home to control, monitor or even adjust a Flow
- Update or install new components in your system
- More and more devices are connected via cloud APIs like OAuth. For instance smart thermostats
- Voice assistants might prove to be a good way to control some aspects of your smart home
![Homey and Google Home Mini work right out of the box](https://blog.athom.com/wp-content/uploads/2019/05/Google-Home-Mini-1024x683.jpeg)
![](https://blog.athom.com/wp-content/uploads/2018/11/app-1024x789.png)
The choice
![](https://blog.athom.com/wp-content/uploads/2020/05/image-3.png)
