🖤 Save A$87 on Homey Pro and 12.5% on everything else with code BLACKFRIDAY24
Raspberry Pi automation or Homey? Compare Domoticz, Home Assistant and Homey
Is a Raspberry Pi-based solution for smart home the best option for you?
Domoticz and Home Assistant are the most popular Raspberry Pi automation systems. Homey is the most popular off-the-shelve smart home platform.
Pricing
Homey Raspberry Pi- based
Base Price € 299 € 65 1
Wireless technologies
   Z-Wave Plus ✔️ included + € 50 2
   Zigbee ✔️ included + € 50 3
   Wi-Fi ✔️ included ✔️ included
   Bluetooth Low Energy ✔️ included ✔️ included
   433 MHz - Trust / DIO ✔️ included + € 100 4
   433MHz - Somfy ✔️ included + € 100 4
   Infrared ✔️ included + € 30 5
   KNX-IP ✔️ included + advanced configuration
Out of the box cloud services ✔️ included + $5 /month (HA)
❌ (Domoticz)
4 RFXcom setup
5 Broadlink RM 3 Mini
Raspberry Pi Automation kit or Homey - Domoticz, Home Assistant OpenHAB
A Raspberry Pi automation solution (left) costs the same, and with services more, than Homey (right)
Capabilities
Homey-supported brands 2020
A lot of brands are active in Smart Home. Homey connects to 1000+ different ones, including these
Home Assistant Spotify Connect integration
Raspberry Pi automation systems like Home Assistant require more advanced setups for cloud services like Spotify Connect
Home automation in Domoticz
Raspberry pi automation with Domoticz
Automation in Domoticz is visual coding in the Blockly editor. It is versatile, but has quite the learning curve - especially for non-programmers.
Raspberry pi automation with Home Assistant
This is the action to turn on all lights in Home Assistant. Despite the GUI, there's still programming involved.
Home automation in Homey
Homey Flow mac iphone web mobile
Automation in Homey is easy and powerful with Homey Flow
The Homey App is a mobile-first experience to easily manage your entire smart home
Flexibility and maintenance
  1. Remote access to your home to control, monitor or even adjust a Flow
  2. Update or install new components in your system
  3. More and more devices are connected via cloud APIs like OAuth. For instance smart thermostats
  4. Voice assistants might prove to be a good way to control some aspects of your smart home
Homey and Google Home Mini work right out of the box
Voice Assistants like Google Home / Google Assistant work out-of-the-box with Homey, without any subscription services
Homey provides a friendly, premium experience for all household users.
The choice
