Discover the new Homey Portal
How Homey Pro Strengthens and Simplifies Your Zigbee Network
A strong Zigbee network can make your smart home feel effortless. Lights turn on exactly when you walk into a room, sensors respond instantly and your automations run quietly in the background. But the real magic happens when you pair Zigbee with the right controller.
Homey Pro is designed to get the very best out of Zigbee, turning a good network into a great one by giving you visibility, flexibility and complete control. This article explores how Homey strengthens your Zigbee mesh, improves daily performance and makes your entire smart home feel more unified.
A Zigbee Network That Grows Stronger With Homey
Zigbee networks thrive when the mesh is healthy. Every powered Zigbee device such as a plug or bulb becomes a router that extends and reinforces the network. Homey Pro recognizes this naturally. As soon as you start pairing Zigbee devices, Homey builds a mesh where messages move through the shortest and most reliable routes.
Because Homey supports Zigbee natively, it can manage large and complex networks with ease. You can add devices from many brands and trust that they will communicate smoothly. Whether you place a single sensor in a hallway or dozens of Zigbee devices across multiple floors, Homey keeps everything connected and responsive.
Fast, Local Automations Powered by Zigbee
Homey Pro processes Zigbee triggers locally. This means your sensors respond quickly even if your internet is having a bad day. Motion sensors feel instant, contact sensors update smoothly and buttons behave consistently.
For example, an Aqara Motion Sensor can trigger a lighting scene the moment you walk into a room. A Zigbee button like the IKEA Styrbar can activate movie mode with a single tap. The reliability comes from Zigbee’s local communication combined with Homey’s powerful automation engine.
Because Homey supports multiple protocols, these routines can blend Zigbee devices with Matter lights, Z-Wave switches or Wi-Fi appliances. Your Zigbee sensors become the heartbeat of your entire home.
Better Stability Through Smart Placement
Zigbee relies heavily on physical device placement. A router hidden behind a metal cabinet or tucked behind a TV can significantly weaken your mesh. Moving a router just a few centimeters or placing it outside a cupboard often resolves signal issues immediately.
If a bedroom sensor drops occasionally, a poorly placed obstacle is usually the culprit. Adding a Zigbee smart plug in the hallway provides a clear bridge for the signal to travel. Strategic placement ensures your devices have the strongest possible path back to the coordinator.
A Controller That Embraces Old and New Technologies
Homey Pro Connectivity Protocols
Homey Pro is the only smart home hub that supports Zigbee, Z-Wave, Wi-Fi, IR, Bluetooth, 433 MHz, Matter and Thread in one device. This makes it possible to continue using your reliable Zigbee sensors while adding new Matter or Thread devices whenever you like.
Your smart home becomes truly flexible. A Zigbee temperature sensor can adjust a Thread based plug. A Z-Wave wall switch can control Zigbee lighting. A Zigbee door sensor can trigger a Matter compatible plug such as the Eve Energy. Homey turns different standards into one seamless ecosystem.
Keeping Your Zigbee Devices Future Ready
There is often concern about future proofing, especially with the rise of Matter. Homey Pro ensures your existing Zigbee devices remain useful for many years. Zigbee continues to be widely supported, and Homey’s Matter Bridge app even lets you expose certain Zigbee devices to Matter ecosystems like Apple Home or Google Home.
With Homey at the center, your devices stay relevant long after purchase, and you avoid the pressure to replace what already works well.
Configuring the Matter Bridge app in the Homey Web App
Zigbee becomes truly powerful when paired with a controller that understands it completely. Homey Pro gives your Zigbee network the strength, structure and intelligence it needs to perform at its best. With fast local processing, multi protocol support and seamless automation, Homey transforms your Zigbee devices into a smart home foundation that feels intuitive and future friendly.
If you want a Zigbee network that works beautifully today and remains flexible for tomorrow, build it with Homey at the core.
Does Homey Pro support Zigbee out of the box?
Yes. Homey Pro includes a built in Zigbee radio.
Do Zigbee devices run even if the internet is down?
Yes. Zigbee communicates locally and Homey processes triggers inside your home.
Can I mix Zigbee with Matter or Thread devices?
Yes. Homey allows Zigbee devices to interact with Matter, Thread, Z Wave and Wi Fi devices in Flows.
Do Zigbee routers improve stability?
Absolutely. Smart plugs and bulbs that stay powered make your mesh stronger.
Can Homey expose Zigbee devices to Matter apps?
Yes. The Homey Matter Bridge app allows this for many devices.
What causes Zigbee drops?
Often weak signal routes or placement behind large obstacles. Homey helps you identify and fix them.
Does Homey work with multiple Zigbee brands?
Yes. Homey supports a wide range of Zigbee manufacturers.
Is Homey good for large Zigbee networks?
Yes. Homey manages complex networks with many devices efficiently.
Do I need to replace Zigbee with Matter?
No. Zigbee remains highly relevant. Homey lets you use both technologies side by side.
