What is Matter?
What is Matter?
Explaining the World’s Latest Smart Home Standard.
Matter at a Glance:
  • Communication standard for smart home devices.
  • Coordinated by a Matter hub, like Homey Pro or Homey Pro mini
What is Matter?
Why Matter Matters?
Homey-Pro-hub
Matter Basics: How It Works
Matter technology stack.
In short:
What is Mesh Networking
Mesh networking, like Thread, means nodes can relay signals, increasing the effective range.
What’s in a Matter Network?
The Matter hub is the brains of your network. The coordinator can connect smart devices, set permissions, allow other devices access, and coordinate your network. The Matter hub also delivers the interfaces you use to control your Matter network. This can be an interface for automation, like Homey Flow, Energy data like Homey Energy and Homey Insights, or a simple a control interface. The Matter hub is also the gateway to the internet for the Matter network. And some smart home hubs, like Homey Pro, connect your Matter devices to devices that use other protocols, like Zigbee, Z-Wave, Infrared or 433MHz
Thread Network Topology
Homey Pro acts as a Thread Border Router, bridging Thread devices to IP networks
Sometimes, a Matter hub is also a Thread border-router. This is the case if the Matter hub includes Thread itself as well, like Homey Pro and Homey Pro mini.
These devices are either the destination or source of data transmitted. Often powered by a small battery, this device does not repeat or forward any signals. I.e., this is the end of your network. In most cases, standard Matter devices will either be on LAN (like Wi-Fi) or will be Thread Mesh Extenders. Unless you choose battery-operated devices such as wireless buttons, simple sensors, etc. These are typically end-devices because that allows them to work much longer on one battery load.
Matter devices
Which Devices Support Matter?
  • Manufacturer-Specific Advanced Features: This is the most common limitation. While a device like a smart light bulb works with Matter (on/off, color control), its rich, unique features—such as dynamic lighting scenes, specific energy monitoring data, specialized security modes, or complex appliance diagnostic readouts—are often not exposed to third-party ecosystems via the Matter standard. You still need the original manufacturer's app to access them (e.g., Hue's Entertainment Mode, or advanced thermostat scheduling).
  • Security Camera/Video Doorbell Intelligence: While Matter 1.5 officially introduced native support for cameras (including live video/audio streaming and pan-tilt-zoom control), the standard does not handle video analysis or intelligence. This means features like AI-based person/pet recognition or triggering automations based on detected events still rely on the manufacturer's own software and cloud services
  • Highly Specialized Systems: Some niche or proprietary multi-component audio/video systems (like specialized multi-room audio) or high-end integrated home security systems (beyond basic locks and sensors) may not yet have complete, feature-rich Matter integration and often rely on their own APIs or protocols for complex functionality.
Why Use Matter?
Interoperability
Most Matter devices work together no matter which brand makes them (mind the LAN / Thread difference though!). However, this only applies to all Matter devices, not to all the other smart home devices on other technologies. This makes the interoperability-claim a bit similar to the same one from Zigbee and Z-wave at the moment. Matter has some momentum and a lot of manufacturers behind it, although the first companies are also dropping out again. Its full interoperability claim has yet to come true as well. In the end, universal smart home hubs that combine Matter and other technologies will always be the most interoperable.
Security
Simplified User Experience
Most Matter hubs, like Homey Pro, feature intuitive interfaces for smart home control and automation. Also, the Matter protocol includes a simple pairing process.
Local by design
Power-Efficient
Because Thread is a part of the Matter protocol, Matter devices can be very power-efficient. Thread end-devices use very little energy when in standby, which greatly reduces electric usage and improves battery life where relevant. Again, the same holds for Zigbee and Z-Wave devices.
Multi-admin Control
Disadvantages
Limited Device Categories
Thread Network Dependency
Homey as a Matter Controller
Homey Pro is one of the most complete Matter hubs available. It supports eight major smart home technologies, including Zigbee, Z-Wave, 433MHz, Infrared, BLE, Wi-Fi, Thread — and, of course, Matter. This makes it uniquely positioned to bridge the gap between today’s mixed-technology smart home and tomorrow’s Matter-powered world.
Getting Started With Matter
Step 1: Choose a Matter hub. We obviously recommend Homey Pro or Homey Pro mini. It allows you to also stay flexible with regards to other smart home technologies.
Step 3: Setup your hub.
A truly comprehensive smart home hub, like Homey Pro, features a blend of protocols. The ideal hub or controller for your setup is one that can seamlessly manage and automate devices across all the technologies you choose to use.
Homey Pro Matter hub
Frequently Asked Questions
Is Matter secure?
