🖤 Save £50 on Homey Pro and 12.5% on everything else with code BLACKFRIDAY24
The protocols
Wi-Fi
Zigbee
philips hue zigbee bridge
The sockets
The colours
White dimmable bulbs
White tunable bulbs
Colour bulbs
The accessories
There you go!
Happy shopping!
