Port Forwarding is now live
In the last few months, we've rolled out updates to the Homey apps for iOS, Android, and Web to fully support Port Forwarding on Homey Pro (Early 2023).
What is Port Forwarding?
When you open the Homey iOS, Android, or Web app, an advanced algorithm tries to find the fastest & most secure route to your Homey Pro.
Port Forwarding is another method for when you're away from home. It bypasses our cloud services entirely and goes straight to Homey Pro. This means it's faster and more reliable. It just requires a one-time setup on your Wi-Fi router, enabling direct traffic to your Homey Pro from outside your home network.
Within the Homey app, navigate to More → Settings → General → Port Forwarding. Toggle on Enable Port Forwarding, and enter the external port you've chosen in step 2. In our example, we picked port 4859.
That's it! The Homey app for iOS, Android, and Web will now prefer Port Forwarding when you're not home. And if it stops working for any reason, our cloud relay will automatically be selected as a backup route.
