Automate Your Morning Routine with Homey
Waking up quickly and suddenly can feel unpleasant. One moment you're sleeping, the next, the day demands your full attention. But what if your morning could unfold smoothly instead? What if Homey helped you ease into the day, feeling refreshed and ready?
With a few clever Flows, you can turn a chaotic wake-up into a smart, seamless routine. Let Homey be your partner to automate everything from sunlight gradually filling your room to your coffee brewing perfectly, starting your day in harmony.
Gradual Awakening with Natural Light
Remember the sharp, sudden sound of an alarm clock tearing you from deep sleep. It's a common, but unpleasant and outdated start to the day. Being jolted out of a dream can ruin your entire mood for the day and leave you feeling on edge for hours. Now, picture something completely different.
Imagine being woken up by gentle, natural sunlight instead. With Homey, your smart curtains and blinds become a key part of this peaceful wake-up. You can connect popular devices like Eve, Somfy, or IKEA smart blinds and let Homey gradually open them in the morning. Sunlight fills your room, naturally signaling your body to wake up. This helps you transition from deep sleep to wakefulness smoothly, making your morning feel much more refreshed and less stressful.
Automate Your Morning Routine with Homey: Morning Curtains Open
For winter days, when the sun is still hiding, you can even take this automation up a notch by integrating an indoor light sensor. If the room remains too dim after the blinds open, Homey can subtly activate your smart lamps to gradually increase light, truly mimicking a natural sunrise even on the cloudiest days.
Morning Refreshments
While sunlight is gently waking you up, Homey is working behind the scenes on the rest of your morning routine. Nobody wants a cold shower to start their day. You can set up a Flow where Homey checks your water boiler's temperature. If needed, it begins heating the water well before you wake up. This means a warm, inviting shower is ready for you precisely when you need it.
While you are in the shower, detected by the rising humidity level, Homey starts brewing you an espresso. You can connect your smart coffee maker to Homey and trigger it with a Flow. If you have a non-smart device, simply install a SwitchBot Bot, a mechanical button pusher to active your coffee maker. Imagine walking into your kitchen to the rich aroma of freshly brewed coffee.
Automate Your Morning Routine with Homey: Coffee Maker Flow
For those that prefer music or chatter in the morning, set up a Flow to start your favorite calming playlist through your smart speakers the moment you step into the kitchen. Or, if you prefer to stay informed, have Homey deliver a quick news briefing or your latest Spotify podcast.
Leaving Your Home Secure
Once you are ready to leave, Homey makes sure your home is left safe, secure and energy-efficient. Your "Leaving Home" routine can activate as soon as you step out the front door, triggering a series of Flows, making sure you leave no loose ends.
The first Flow automatically locks your front door, giving you peace of mind that your home is sealed tight. A few minutes later, Homey activates and arms your alarm system, protecting your home from any unwanted intrusions without you lifting a finger. To make sure everything worked properly, Homey also sends you a notification, informing you of the current state of your security devices.
Automate Your Morning Routine with Homey: Smart Lock
Beyond security, Homey also ensures your home is energy-efficient while you are away. It automatically turns off lights you might have forgotten and powers down devices that should not run when no one is home. A Flow also optimizes your smart thermostat while you are at work, adjusting the temperature to save energy. With Homey, your home remains fully protected and properly managed for optimal energy savings.
Get Started Today
Ready to transform your morning routine into a seamless experience? With Homey, the power to create your ideal automated day is at your fingertips. Get started for free with Homey Cloud, or go full-on with Homey Pro.
FAQs
Can Homey wake me up with light instead of an alarm sound?
Yes. Homey can gradually open connected smart curtains or blinds, and on darker mornings, slowly brighten smart lamps to mimic a natural sunrise.
How does Homey know when I'm in the shower?
A rise in humidity, picked up by a sensor, can trigger a Flow that starts brewing your coffee, so it's ready when you step out.
Can I automate a non-smart coffee maker with Homey?
Yes. A device like a SwitchBot Bot can physically press the button on a non-smart coffee maker, letting Homey trigger it as part of a Flow.
What happens automatically when I leave the house?
A "Leaving Home" routine can lock the front door, arm the alarm system, turn off forgotten lights, and adjust the thermostat to save energy.
Will Homey warn me if something didn't lock or arm properly?
Yes. Homey sends a notification confirming the state of your security devices, so you know everything worked as expected before you're out the door.
Flow
A rule in Homey that connects a trigger, such as a sensor reading or a door opening, to one or more automated actions.
Light Sensor
A device that measures ambient brightness in a room, used to trigger lighting adjustments when natural light isn't enough.
Humidity Sensor
A device that detects moisture levels in the air, able to recognize activity like a shower running and trigger a Flow in response.
Smart Lock
A connected door lock that can be controlled remotely or automatically, often used to secure a home as part of a leaving routine.
Leaving Home Routine
A set of Flows triggered when someone leaves the house, typically covering security, lighting, and energy-saving actions.
