Control Z-Wave devices with Google Home using Homey
Z-Wave devices don’t connect directly to Google Home. To control Z-Wave lights, switches, or sensors with Google Home, you need a smart home hub that supports Z-Wave and can make those devices available to Google’s platform.
Homey acts as that hub. It connects to Z-Wave devices and exposes supported devices to Google Home. Homey stays in control of the devices. Google Home becomes an additional way to control them.
What you need
To control Z-Wave devices with Google Home, you need:
Z-Wave devices must always be paired with Homey first, before they are added to Google Home.
What “exposing devices” means
When Homey exposes a Z-Wave device to Google Home, it means Homey shares that device with Google Home through its integration.
The device:
  • stays paired with Homey
Google Home does not communicate with Z-Wave devices directly. Commands are routed through Homey.
A simple way to think about it: Homey translates Z-Wave devices into controls Google Home understands.
How to connect Homey to Google Home
You don’t need to re-pair Z-Wave devices or change how they’re connected.
The process works like this:
  1. Pair Z-Wave devices with Homey
    Open the Google Home app, choose Add / Set up device, select Works with Google, choose Homey, and allow Google to access your Homey account.
    After linking, Google Home automatically imports the supported Homey devices.
After this, your Z-Wave devices appear in Google Home without any additional pairing steps. The devices remain paired only with Homey.
How the connection works
    Google Home communicates with Homey via the Homey cloud integration. not with Z-Wave devices directly.
  3. Homey forwards commands
    When you control a device in Google Home, Homey translates the command and sends it to the Z-Wave device.
Once exposed, Z-Wave devices usually appear in Google Home as standard smart devices, such as:
  • Switches and plugs
You can:
  • Assign devices to rooms
What to keep in mind
  • Not all Z-Wave features are available in Google Home
Use Google Home for control and voice and Homey for automation and logic.
In short
Z-Wave devices can’t connect directly to Google Home.
Homey exposes them by making them visible and controllable in Google Home, while keeping all Z-Wave communication and advanced automation inside Homey.
Google Home becomes an additional way to interact with your devices and Homey stays in control.
