Stepping into a hot sauna should feel effortless, not like a chore you have to manage. With Homey, your sauna stops being a switch you flip and becomes part of your smart home routine.
Why a Smart Sauna Feels So Natural
There's something special about stepping into a warm sauna after a long day. The soft glow, the rising heat, the quiet in the air, it's a moment of stillness right inside your home. But in many households, that comfort still depends on old fashioned controls, fiddling with timers, waiting for the cabin to heat up, and hoping everything switched off correctly afterward.
With Homey Pro, your sauna becomes part of a wider smart home rhythm. Instead of a stand alone wellness corner, it turns into a personalized, automated experience that prepares itself for you, and looks after itself when you're done.
A smart sauna isn't about gadgets for the sake of gadgets. It's about convenience, safety, and consistency. When your sauna connects with Homey Pro, it can warm up before you even arrive home, it can keep a comfortable temperature without overshooting, and it can switch off reliably so you never waste energy. Lighting, music and ventilation fall into place automatically, so every session starts exactly the way you want.
Rather than thinking, "I should go turn the sauna on," your sauna simply becomes ready when you are.
One Control Unit, Endless Comfort
Behind every smart sauna sits a control unit, the heart of the system. Modern heaters and controllers can already be connected through Wi-Fi or external relays, and that's where Homey comes in. Once linked, the sauna works like any other integrated device in your home.
Homey gives you full control over heating and timing, and can help regulate temperature safely. It can guide the lighting and ambience, cooperate with humidity and ventilation where supported, and even bring sound into the experience so your session begins with calm music or a guided meditation.
Most saunas already have the pieces needed for smart control. Homey simply ties them together.
Your Sauna, Exactly When You Want It
Many sauna owners dream of stepping inside the moment they walk through the door. With smart automation, that becomes normal rather than a luxury. You can let Homey start preheating when you leave work, or automatically at the end of your evening routine. If your sauna needs extra warming time in winter, Homey can adjust for that too.
Once the session starts, your sauna quietly keeps the temperature steady. If you prefer a slightly warmer start and a gentler finish, you can create a routine that follows your personal rhythm. And when you're done, Homey takes care of shutdown, ventilation and lighting so everything returns safely to standby.
Suddenly your sauna doesn't just work, it takes care of the entire ritual around it.
Creating Ambience That Matches the Moment
Lighting plays a big role in how a sauna feels. Homey can tune the lights inside and around the sauna to create a clear, cohesive atmosphere. Warm amber tones for a slow evening, or brighter lighting after sports, all triggered by starting your sauna session. If you enjoy sound during your sessions, Homey can start a playlist or calming nature audio as soon as the cabin reaches temperature.
Even elements around the sauna can respond. Bathroom lights can dim, hallway lighting can guide your path, and the house can switch to a quieter mode. Everything falls in line with the same intention, making your home feel like a private spa.
Safety and Peace of Mind Built In
A sauna uses high temperatures and significant power, so smart control needs to feel safe above all else. Homey helps by keeping an eye on run time, temperature, and usage. If the sauna runs longer than normal, if the door remains open while heating, or if the heater suddenly draws more power than expected, Homey can send a warning to your phone.
All safety features in the sauna remain fully intact. Homey simply adds an extra layer of awareness, so you don't have to walk back and forth to check whether everything is in order.
A Sauna That Becomes Part of Your Whole Home
What makes a smart sauna truly special is how naturally it blends into the rest of your smart home. When you begin a session, your home can mute notifications, lower blinds, activate soft lighting in the bathroom, or reduce other heavy loads on the grid. When you finish, the house can ventilate automatically, bring lights back up and restore normal routines.
Over time, your sauna becomes part of your daily or weekly rhythm. It's no longer "that warm cabin in the corner," but a well integrated piece of your wellbeing, just as natural as your smart heating or lighting.
The Upgrade That Changes the Entire Experience
A smart sauna feels less like an appliance and more like a service your home provides. It's warm when you walk in, calming when you sit down, and safe when you close the door behind you. With Homey Pro acting as the brain behind the experience, every session becomes smoother, more intuitive and more energy efficient, without adding extra complexity.
A sauna might already be your quiet moment of the day. Making it smart simply ensures it's always ready for you.
Conclusion, A Smarter Sauna Is Simply a Better Sauna
A smart sauna transforms a traditional wellness feature into a seamless part of your lifestyle. It warms up when you want it, creates the right atmosphere automatically, protects itself during use and switches off safely when you're done. With Homey Pro as the intelligent layer underneath, your sauna stops being a stand alone appliance and becomes a true piece of your smart, comfortable, energy aware home.
Once you've experienced it, it's hard to imagine going back to analog switches and timers.
FAQ, Smart Sauna and Homey Pro
Can every sauna be made smart with Homey?
Many modern saunas can be connected directly or through dedicated Wi-Fi control units. Older models often require sauna rated modules and relays. Compatibility and electrical safety should always be checked by a professional installer.
Can I safely turn my sauna on remotely?
Yes, as long as your sauna's control unit supports safe remote activation. Most certified smart controllers include door sensors, overheat protection and mandatory safety checks. Homey adds automation and notifications on top of these systems.
Do I need new lighting or audio equipment?
No. Homey can integrate with existing smart lighting and speakers, or you can upgrade gradually using sauna rated LED lights or moisture resistant speakers. Homey brings the devices together, whatever their brand.
How does Homey help reduce energy use?
Homey can prevent the sauna from running unnecessarily, shorten warm up time through scheduling, and manage ventilation after your session. It can also coordinate heavy loads in the home to avoid peak usage.
Will the sauna still work if my Wi-Fi goes down?
Yes. Homey Pro runs locally, meaning your automations continue to work even without internet. Only cloud based features, such as remote notifications, may pause temporarily.
Smart Sauna
A sauna that can be controlled digitally or remotely, often featuring automation for heating, lighting and safety.
Control Unit
The device that manages sauna heating, timing, sensors and sometimes lighting or humidity.
Preheating
Starting the sauna in advance so it reaches your preferred temperature by the time you're ready.
Ambience Automation
A set of coordinated actions, lights, audio, ventilation, that create a specific mood when a sauna session starts.
Local Automation
Automations processed entirely within Homey Pro, ensuring reliability and performance even without an internet connection.
