Homey for Airbnb: A Smarter Way to Run a Rental
Short-term rental hosting is built on a simple but powerful idea: trust. You open the door to a home you care about — maybe a city apartment, a holiday cottage, a beach house, or a carefully renovated family property — and you trust guests to enjoy it responsibly.
Most guests do. Still, every host knows the small worries. The air conditioning left at 18°C all day. The bathroom fan forgotten after long showers. A window left open during a storm. A front door that may not be locked. A weekend booking that suddenly feels a little too lively.
That is where Homey Pro becomes a strong companion for Airbnb hosts and other short-term rental owners. Not as a surveillance tool, but as a smart home hub that helps the house take care of itself. Homey can connect access, lighting, heating, cooling, sensors, safety devices and guest controls into one calm, practical system.
The goal is simple: a better stay for guests, and more peace of mind for hosts.
Start with a home that feels easy to use
A smart rental should never feel complicated. Guests should not need to install three apps, a printed manual, or a send late-night message to the host just to turn down the heating. The best setup starts with simple control.
A wall-mounted tablet can show a Homey Dashboard with only the buttons guests actually need: Check in, Check out, lights control, bathroom ventilation, or a leaving for the day routine. With Homey Dashboard in Kiosk Mode, the interface stays clean and focused, so guests cannot accidentally change deeper settings.
Behind those friendly buttons, Homey runs the real magic. A single tap can turn off lights, adjust the temperature, activate ventilation, or prepare the home for cleaning.
From a dumb house to a smart rental
| Rental area | Smart upgrade | Simple Homey use case | Why hosts love it |
| Entrance | Smart lock | Guests enter without a physical key | Easier check-in, fewer lost keys |
| Welcome screen | Homey Dashboard in Kiosk Mode | Guests tap Check in or Check out | Simple guest control without app confusion |
| Entrance area | Smart doorbell | Entrance activity is visible where allowed and disclosed | Helps manage arrivals and access |
| Climate | Smart thermostat or air conditioner | Cooling or heating adjusts when guests leave | Less energy waste, more comfort |
| Bathroom | Temperature and humidity sensor | Ventilation starts when humidity rises | Helps prevent damp air and mold |
| Safety | Smoke and CO detector | Host receives an urgent safety alert | Faster awareness when it matters |
| Water risk | Water leak detector | Alert when water appears near a sink or appliance | Helps prevent expensive damage |
| Windows and doors | Door/window sensor | Alert if a window is open while AC runs | Saves energy and protects the property |
| Lighting | Smart lights | Lights turn off automatically after check-out | Better turnover and lower energy use |
| Appliances | Smart plug | Forgotten devices switch off after check-out | Reduces standby use and risk |
| Movement for comfort | Motion sensor | Hallway lights turn on softly at night | Better guest experience |
| Noise awareness | Disclosed decibel sensor | Alert when noise levels stay high during quiet hours | Helps protect neighbors without recording audio |
Make check-in feel effortless
One of the most stressful parts of travel is arrival. A guest may arrive late, tired, carrying luggage, stumbling to find the entrance in the dark. A smart rental can make that first moment feel easy and calm.
Airbnb supports connecting compatible smart locks directly for eligible hosts in some regions. According to Airbnb, once a compatible smart lock is connected to a listing, guests with confirmed reservations can automatically receive a unique code that is active only during their stay.
Homey can work beautifully alongside that kind of access setup. When a guest enters, Homey can turn on the hallway lights, set the climate to a comfortable level, and show a welcome screen on the Dashboard. No complicated instructions. No searching for switches. Just a home that feels ready.
Stop energy waste without nagging guests
Guests are on holiday. They are packing beach bags, heading into town, or rushing to catch a dinner reservation. It is easy to forget the AC, heating, lights, or bathroom fan.
Homey helps the home respond gently. If the property seems empty, Homey can set the air conditioner or smart thermostat to a more efficient temperature. If a door/window sensor notices that a window is open while cooling is active, Homey can send a notification or pause the climate system. After check-out, Homey can turn off lights and selected appliances through smart plugs.
The guest still enjoys comfort. The host avoids paying to cool an empty room with an open window.
Keep bathrooms fresh and healthy
Bathrooms in rental homes work hard. Guests shower after the beach, after a hike, before dinner, and sometimes one after another. If ventilation is forgotten, humidity can stay in the room for hours.
A temperature and humidity sensor can help Homey notice when moisture rises. Homey can then turn on ventilation automatically, keep it running until humidity drops, and switch it off again later.
It is a small automation with a big practical benefit. The bathroom feels fresher for guests, and the host reduces the chance of damp smells, peeling paint, or mold.
Support safety without watching guests
A smart rental should be built around safety-first, privacy-friendly devices. A smoke and CO detector can alert the host when there is a serious issue. A water leak detector can warn about a leak before it becomes a damaged floor. And a door/window sensor can show whether the property was left open after check-out.
These are not devices for watching people. They help the home report practical conditions: smoke, water, humidity, open windows, temperature, and energy use. With Homey, the property is always safe and secure, without intruding on your guests privacy.
For a deeper explanation of guest privacy, camera placement, decibel sensors, and disclosure, read our companion guide: How To Run A Privacy-First Airbnb Rental with Homey
Handle noise issues earlier and more respectfully
Noise is one of the biggest concerns for short-term rental hosts, especially in apartments, townhouses, and quiet holiday neighborhoods. A disclosed decibel sensor can help hosts respond before a situation becomes a neighbor complaint.
The key is that a decibel sensor should measure sound level and duration only. It should not record conversations or transmit audio. Airbnb’s policy describes noise decibel monitors as devices that assess sound levels and duration but do not record audio, and says these devices must comply with Airbnb’s rules and applicable laws.
With Homey, a Flow could send a notification if sound levels stay unusually high during quiet hours. The host can then send a friendly message: “Hi, just a quick reminder that quiet hours have started. Thanks for helping us keep the neighbors comfortable.”
That is not spying. It is responsible hosting.
Make check-out simple
Check-out is when small things get missed. Lights stay on, the heating keeps running, a window remains open or guests forgets to lock the door.
A large Check out button on the Homey Dashboard, or a physical smart button near the exit, makes the final step easy. Tap once, and Homey can switch off smart lights, adjust the climate, turn off selected appliances, check windows and doors, and notify the host or cleaner.
It feels simple for the guest and gives the host a calmer turnover.
Help cleaners and maintenance teams
Smart technology is not only useful during the guest stay. It also helps between stays.
After check-out, Homey can prepare the home for cleaning. Hallway lights can turn on. Climate can switch to a comfortable cleaning temperature. The cleaner can receive a notification that guests have left. If a leak sensor, smoke detector, or window sensor needs attention, the host can know before the next guest arrives.
This is where Homey becomes more than a smart home system. It becomes part of a smoother hosting operation.
Why Homey Pro is ideal for short-term rentals
Rental homes often contain a mix of devices. Smart lights and thermostats from one brand, lights and sensors from another. Homey Pro is a great choice because it brings many brands and technologies together in one place.
That gives hosts fewer apps to check, fewer routines to manage manually, and more ways to connect comfort, safety, energy, and operations. For guests, the home feels polished but not complicated. For hosts, the property feels more protected without becoming intrusive.
A great smart Airbnb rental is not about filling a home with gadgets. It is about creating a stay that feels smooth for guests and manageable for hosts.
Homey Pro can help welcome guests, reduce energy waste, improve bathroom ventilation, support safety, simplify check-out, and keep hosts aware of issues that truly matter. With the right setup, even a completely dumb house can become a calmer, more responsible, more guest-friendly rental.
Ready to make your rental smarter? Start with one meaningful upgrade — a smart lock, a check-out Flow, a humidity sensor, or climate automation — and let Homey help your home take care of itself between every stay.
Is Homey Pro useful for Airbnb hosts?
Yes. Homey Pro can connect access, lighting, climate, safety, sensors, and guest controls into one smart rental system.
What is the best first smart device for a rental?
A smart lock is often the best first step because it makes check-in easier and reduces key problems.
Can Homey help reduce AC costs?
Yes. Homey can adjust cooling when the home is empty, when windows are open, or after check-out.
Can Homey help with bathroom ventilation?
Yes. A humidity sensor can trigger ventilation when moisture rises after showers.
Can Homey help detect leaks?
Yes. A water leak detector can alert the host before a small leak becomes expensive damage.
Can Homey help with parties?
Homey can help detect unusual patterns through privacy-friendly sensors and disclosed decibel monitoring, but it should not be used to spy on guests.
Does a Homey-powered rental watch guests?
No. A responsible Homey setup is about safety, comfort, energy, and property protection. For more detail, read the companion privacy-first smart rental guide.
Can guests control Homey?
Yes. A Homey Dashboard in Kiosk Mode can give guests simple buttons without exposing advanced settings.
Can Homey help cleaners?
Yes. A check-out Flow can notify cleaners, reset climate, turn on lights, and show whether sensors need attention.
Do hosts still need to follow Airbnb rules?
Yes. Hosts must follow Airbnb policies, local laws, and disclosure requirements for smart locks, cameras, decibel monitors, and smart devices.
Homey Pro
A smart home hub that connects devices and runs automations.
Flow
A Homey automation that connects triggers, conditions, and actions.
Kiosk Mode
A locked Homey Dashboard view for shared or wall-mounted guest control.
Homey Dashboard
A visual control screen for devices, scenes, and automations.
Smart lock
A connected lock that can manage access without traditional keys.
Smart button
A physical or digital button that starts an automation.
Door/window sensor
A sensor that detects whether a door or window is open or closed.
Motion sensor
A sensor that detects movement in a room or area.
Humidity sensor
A sensor that measures moisture in the air.
Smart thermostat
A connected thermostat that can be controlled and automated.
Smart air conditioner
An AC unit or controller that can be adjusted automatically.
Smart plug
A plug that can switch appliances on or off and often measure energy use.
A safety device that detects smoke or carbon monoxide.
Water leak detector
A sensor that alerts you when water is detected where it should not be.
Decibel sensor
A device that measures sound level without recording conversations.
Check-out Flow
An automation that resets the rental when guests leave.
Turnover
The cleaning and preparation period between one stay and the next.
Disclosure
Clearly informing guests about smart devices, cameras, or monitoring tools where required.
References and useful links
| Resource | Link |
| Airbnb: Connect a smart lock to Airbnb | Read Airbnb’s smart lock guide |
| Airbnb: Security cameras, recording devices, noise decibel monitors, and smart home devices | Read Airbnb’s device policy |
| Homey Kiosk Mode | Start a Homey Dashboard in Kiosk Mode |
| Smart locks | Explore smart locks |
| Smart doorbells | Explore smart doorbells |
| Smart cameras | Explore smart cameras |
| Smart thermostats | Explore smart thermostats |
| Air conditioners | Explore air conditioners |
| Door and window sensors | Explore door and window sensors |
| Motion sensors | Explore motion sensors |
| Temperature and humidity sensors | Explore temperature and humidity sensors |
| Smoke and CO detectors | Explore smoke and CO detectors |
| Water leak detectors | Explore water leak detectors |
| Smart plugs | Explore smart plugs |
| Remotes and buttons | Explore remotes and buttons |
