Keeping Your Home Running with Backup Power and Load Prioritization
A home battery does more than just store electricity for later. You can keep the devices that matter most running during an outage or when your grid connection is maxed out. This requires backup power and smart load prioritization. Here is how you design and set up the system properly with Homey.
1. Understanding UPS versus True Backup Power
A UPS buffer prevents your modem and lights from going out during short dips. This reduces flickering and restarts. True backup goes further because the inverter can disconnect your home from the grid and supply it independently. You need a backup inverter combined with a critical loads panel or an automatic transfer switch for this.
Not all home battery systems offer this feature. You should opt for island mode with a dedicated panel for critical circuits if you want true outage protection. Island mode means operating off-grid with self-generated power.
2. Selecting Critical Loads
A critical panel forces you to choose what is essential. You should include only what is necessary.
Nice to have loads like an eco-mode boiler or crawl-space pump should be activated manually. High-power devices do not belong on backup. This includes ovens and induction cooktops along with washers and EV chargers. You should disable them via software if needed.
Create Three Levels for Simplicity
  • Level A: Devices always on in an outage such as the fridge and modem along with lighting and heating control.
  • Level B: Nice to have items like the boiler in eco mode and the home office PC.
  • Level C: Luxury items usually left off such as the oven and washer or EV charger.
3. Avoiding Disappointments with Power Ratings
Backup performance depends on continuous inverter power and peak handling. You must choose an inverter with enough continuous and peak power to handle surges like a fridge compressor.
  • Stagger device startup to avoid load spikes.
  • Use soft-start features where possible.
  • Limit the set power for cooking if it must be on backup and accept longer cook times.
4. Setting SoC Reserve and Autonomy
Backup only works when energy is available. You should always reserve 15 to 30 percent State of Charge that is not used for self-consumption. Increase this buffer to 50 or 80 percent when outages are likely due to storms.
You get 8 to 12 hours of autonomy with 5 kWh usable capacity and a 400 to 600 watt average load. A full day is possible with 10 kWh.
5. Managing Automatic Transfer Switching and Safety
An Automatic Transfer Switch changes from grid to island mode in milliseconds or seconds. It must never feed back into the public grid during an outage for legal and safety reasons.
Have switching and separation professionally designed and certified. Label everything in your panel and define who may operate the system. Test quarterly by simulating an outage to confirm operation and log SoC behavior.
6. Prioritizing Loads with Rules
Prioritize your devices to ensure stability.
  • Order: Internet and lights come first followed by cooling and finally ventilation.
  • Power Limits: Set limits per circuit to avoid overloads.
  • Time Windows: Run cooling in duty cycles to save energy.
  • Smart Triggers: Disable comfort loads at low SoC or allow more usage at high PV output.
7. Assessing Heat Pumps and Backup
The control unit of a heat pump is low-power and useful for freeze protection. The compressor draws significant power and drains your home battery fast. Do not run the full heat pump on backup. Use insulation and supplement with low-power heating instead.
8. Handling EVs During Outages
Charging an EV from a home battery during outages is rarely worth it due to high energy demand. It reduces autonomy significantly. Keep the wallbox off during backup by default. Micro-charging via PV may be allowed in special cases but is not a primary solution.
9. Limiting Peaks During Normal Operation
Load prioritization helps even when the lights are on. This is useful where capacity tariffs or limited connections apply.
  • Set peak limits per phase.
  • Let the battery assist when near limits.
  • Auto-pause non-critical loads.
  • Spread large consumers across time such as heating water at midday and charging the EV at night.
10. Monitoring for Control
Start with accurate metering using CT clamps at the main connection. Confirm direction with a known load.
  • Log the SoC profile.
  • Track charged and discharged energy.
  • Record backup events and peak power.
  • Measure outage duration.
Evaluate this data quarterly to see if the panel needs more power or if duty cycles need tuning.
11. Checking Readiness for Outages
A house is outage-ready when specific criteria are met.
  • The inverter supports island mode.
  • The critical loads panel is configured.
  • The ATS is installed and certified.
  • SoC reserves are configured.
  • Circuit power limits are set.
  • The test protocol is documented.
  • An emergency kit is ready.
12. Fixing Common Mistakes
  • Too many loads on backup: The battery drains fast so fix this with strict selection and manual activation.
  • No SoC reserve: The battery is empty when needed so fix this with a fixed buffer.
  • Underestimating peak loads: The inverter trips so fix this with higher peak specifications.
  • High consumers on backup: Predictable failures occur so keep the oven and EV off.
  • Infrequent testing: Problems only show in crisis so test quarterly.
13. Using Effective Flow Examples
Keep your logic simple for reliability.
  • Activate backup profile with critical loads only on grid loss.
  • Reduce limits stepwise at low SoC and disable comfort loads.
  • Allow one temporary extra load on sunny island power.
  • Auto-pause the least critical circuit for a few minutes on peak risk.
Backup power means the right things work rather than everything working. Your home keeps running when it matters most with an island-ready inverter and a well-designed critical loads panel. Clear SoC reserves and thoughtful prioritization complete the system, ultimately managed by Homey.
FAQs
What is a critical loads panel?
It is a dedicated electrical panel that powers essential devices during outages using a battery and backup inverter. It physically separates essential circuits from the rest of the home to ensure they remain powered.
What is island mode?
Island mode means your system runs off-grid and independently from the public electricity supply. The system is called grid-parallel once it reconnects to the utility.
Do I need a separate critical loads panel?
Yes. It is best practice for backup systems. It avoids overloads and ensures safety by preventing non-essential high-power appliances from draining the battery instantly.
How much power do I need for home backup?
Aim for 3 to 5 kW of continuous power for basic comfort. Higher output is possible but expensive. It is more important to only power Level A loads to extend runtime.
Can my heat pump run on backup?
It works in theory but is practically not worth it. The compressor drains the battery very quickly. It is better to run the control electronics only and use other heat sources.
Automatic Transfer Switch (ATS)
A device that automatically switches a power supply from the primary source to a backup source when it detects a failure in the primary source.
Island Mode
The operational state where a distributed generation system like a solar-plus-battery setup continues to power a location independently of the physical utility grid.
Critical Loads
Essential electrical appliances and circuits that must remain operational during a power outage such as refrigerators and medical equipment.
Inverter Power (Continuous)
The amount of power an inverter can supply constantly without overheating or shutting down.
Soft-Start
A feature in appliances or motor controllers that gradually increases voltage to reduce the mechanical stress and current surge during startup.
