Discover the new Homey Portal
Homey vs. Vera Plus - Smart home system comparison
Homey and Vera are both smart home systems available in Europe. But how do the two compare? What are the differences and similarities? Let’s find out.
smart home Homey Animus
Summary
Homey Vera Plus
Supported technologies
   Z-Wave Plus ✔️ ✔️
   Zigbee ✔️ ✔️
   Wi-Fi / LAN ✔️ ✔️
   Bluetooth Low Energy ✔️ ✔️
   868 MHz ✔️
   433 MHz - Trust / DIO ✔️
433MHz - Somfy ✔️
   Infrared ✔️
   KNX-IP ✔️
Voice assistants ✔️ ✔️
Privacy-aware ✔️
Automation Powerful Limited
Energy management ✔️
Price € 299 € 200
LanguagesEN, DE, ES, FR, IT, NL, DK, SE, NO EN, ES, FR
Operation Easy, Fast Harder, Slow
Compatibility and versatility
The comparison between Homey and Vera here is easy: where Vera features four technologies, Z-Wave Plus, Zigbee, Bluetooth Low Energy, and LAN / Wi-Fi, Homey supports seven. Homey also supports Z-Wave Plus, Zigbee and Wi-Fi, and adds 433MHz, 868MHz and Infrared. On a technology like Wi-Fi, Homey also supports more products. Examples include full support for Sonos and Spotify Connect speakers, or an integration with KNX-IP.
Sonos Smart Home speakers work perfectly with Homey
Homey features full support for Sonos and Spotify Connect speakers, including volume and playlist selection.
While it is possible to extend Vera to also support 433MHz, you need to buy an extra RFXcom module and install that on your Vera. This will set you back an extra € 90 at least, and is a less simple solution. Still, Infrared will be missing, as will a lot of Wi-Fi devices.
Platform and development
When you invest in a system, you want to use it for the years to come. When it comes to platform structure and future development, there is one big difference between Homey and Vera: Homey is built as an open platform, while Vera is closed: no external apps can be developed.
The Homey App Store features all published Homey Apps, to be installed with a single click.
Both Homey and Vera feature a mobile app, a web-app for automation, and integrations with voice assistants like Alexa and Google Assistant.
The way these apps and interfaces work and look, though, makes all the difference. Generally, the interfaces of Vera a described as 'slow', 'cumbersome', and 'complicated', while Homey features a very friendly experience. The fact that Homey's computing hardware is much more powerful than Vera's helps too. The most important differences in interface between the two systems can be found in the mobile app.
In short, the Homey app is more extended, more modern, easier to use and faster than that of Vera. For instance, it features extended yet friendly automation options with Homey Flow, right in the mobile app. It also features settings, network management, user invitation, energy management with Homey Energy and many more features not found in the Vera mobile app.
At the same time, the Homey app looks and works more modern than Vera. Despite its options, the Homey app remains easy to use. The more advanced features are positioned well and can be disabled for users by inviting them on a ‘user’ or ‘guest’ level.
Homey mobile app for IOS and Android: Easier and more extended than Vera
The Homey app features a lot of powerful options in a friendly, modern interface.
Vera Plus mobile app
The Vera app contains dated interfaces that have a steeper learning curve - and can do less.
Privacy
Homey is designed privacy-first. Its privacy policy is clear, it doesn’t sell your data, doesn’t do profiling and fully complies with EU GDPR. While Vera's data is stored locally, its privacy policy explicitly allows Vera and the companies behind it to use your (personal) data for marketing purposes.
Visual appearance
Homey visual appearance
Homey's visual appearance.
Vera plus physical appearance
Vera Plus' visual appearance.
The one thing that can be said is that Homey is designed more for the living room, and Vera is less. Of course, Homey can also be put out of sight, but it has some interesting features that might make you want to put it in the living room:
  2. Homey has infrared, which requires a line-of-sight with your TV and/or stereo to work best
Automation
One of the core functions, next to device compatibility is automation. Both Homey and Vera feature automation engines. However, the user interface of the two systems could not be further apart.
Homey Flow editor for automation: easier than Vera.
Homey provides an easy-to-use, yet powerful automation tool with Homey Flow.
Vera mainly has a PC interface to automate your home, which is called 'Scenes'. The interface is quite heavy, and you need to go through a lot of options and functions to create your scene. At the same time, it is less powerful than Homey's, as it misses several options like and... conditions. It is also less flexible and versatile than Homey Flow to build custom, non-standard scenes. Also, Vera's interface definitely has a learning curve.
A couple of system features cannot be properly automated with Vera, like user management and smartphone push notification. You can set push notifications in Vera, but these are not custom, and cannot be set in Scenes.
Vera's interfaces for automation are less versatile and have a higher learning curve than Homey's.
Price
Nothing comes for free, and price is always a factor when choosing products – smart home and non-smart-home. Comparing the price is pretty easy: Homey costs € 299, while the Vera Plus sets you back € 200. With Homey, this is the final price, including technologies like 433MHz and infrared. If you want these options with Vera, you're shelling out more, surpassing the price of Homey. At the same time, you're still stuck with the slower, more cumbersome interfaces of the Vera system.
Homey vs. Vera - Conclusion
Vera has a slightly more extended PC interface than Homey does. However, this interface is slow, and not easy to use. Homey puts all this functionality - and more - in its mobile app. This makes it a lot easier to add or change devices, right from the palm of your hand. Homey also offers more connectivity options, more ease-of-use, an open platform and easier, more flexible automation than Vera at a comparable price.
Homey features some core connectivity like 433MHz (Somfy, DIO, Nexa...) and infrared that Vera doesn't. And even on the same supported technologies, Homey boasts more extended device support and better interfaces for it. Homey Flow is a more flexible and powerful automation engine than Vera has, and it's available fully on both web and mobile. And, most importantly, Homey's open platform with developer community definitely is a more future-proof play.
