Underfloor Heating, Radiators and Buffer Tanks: How to Tune the System
A mixed heating system that utilizes both underfloor heating and radiators requires deliberate coordination to work effectively. Underfloor heating is inherently slow and efficient at low supply temperatures, whereas radiators respond quickly but often require slightly higher temperatures to be effective.
When you add a buffer tank to this mix, you can let your heat pump run more steadily and avoid hydraulic issues. This guide walks you through the key choices for design, configuration, and control, ensuring that your comfort and energy consumption stay perfectly balanced.
Why Combining Makes Sense
Each heat-emission system has its own specific strength. Underfloor heating delivers even, consistent warmth and makes optimal use of low water temperatures, which is ideal for heat pumps. On the other hand, radiators give off heat quickly, which is convenient for rooms you use less frequently or only for shorter periods, such as bedrooms or home offices.
By combining both, you can keep your main living areas comfortable and efficient while remaining flexible in study rooms, guest rooms, or attics. Furthermore, introducing a buffer tank helps the heat source run longer cycles and functions as a crucial hydraulic separation between the energy source and the emission systems.
Temperatures and Limits
To get the best performance, you need to respect the temperature limits of each system. Underfloor heating performs best at a supply temperature of 28–35°C in spring and autumn, rising to 35–45°C in colder weather, depending on your insulation and floor finish. For safety and comfort, you should maintain a maximum floor surface temperature of around 29°C in living areas and 33°C in bathrooms.
Radiators, however, vary significantly. Modern low-temperature radiators or convectors perform well at 35–50°C, while classic radiators often require 50–60°C to deliver equivalent output. It is important to remember that the lower the supply temperature, the better the efficiency of a heat pump—and the more often a high-efficiency boiler can condense.
Hydraulic Separation and Mixing
As soon as you want two different temperature regimes, you need either mixing or separation. A manifold with injection mixing or a dedicated mixing group for the underfloor system ensures that the radiator circuit isn’t limited by the lower temperature required for the floor.
Alternatively, you can use a primary–secondary setup with hydraulic separation, where a buffer tank or hydraulic distributor decouples the flow rates. In this scenario, the heat source feeds the primary circuit, while the underfloor heating and radiators connect on the secondary side with their own pumps and, if needed, mixing valves.
Buffer Tank: Functions and Sizing
A buffer tank essentially stabilizes the system. It increases the total water volume, reduces the frequency of on/off cycling, supports defrost cycles in heat pumps, and enables clean hydraulic separation.
For air-to-water heat pumps, a guideline of 10–20 liters per kW of thermal power is often used, though this depends on the minimum output of the heat source and the thermal inertia of your emission system. Ideally, place the tank in the primary circuit, with the supply at the top and the return at the bottom to encourage stratification. Finally, insulate the tank well and install sensors at strategic positions for accurate control and monitoring.
Heating Curve and Parallel Shift
A good heating curve is the foundation of efficient heating. In mixed systems, you should base the curve on the slowest zone, which is usually the underfloor heating. The radiator zone then either receives the same supply temperature—compensated for by having more surface area or fan-assisted convectors—or gets its own higher curve via a mixing group.
The slope determines how strongly the supply temperature follows the outdoor temperature, while the parallel shift raises or lowers the entire curve. You should adjust these settings in small steps and observe the results for several days. If the living room warms too slowly, increase the curve slightly; if you experience temperature overshoot, decrease it.
Flow Rate, ΔT and Balancing
Stable flow and the right temperature drop (ΔT) are crucial for efficiency. For underfloor heating, aim for 2–3 liters/minute per loop as a starting point, with a ΔT of 5–7 K at low supply temperatures. For radiators, a wider ΔT of 10–15 K is typical.
To achieve this, use flow meters on the manifold, set loops according to their length and resistance, and balance radiators using preset valves. Additionally, an automatic differential pressure valve helps the heat pump run more steadily when thermostatic valves close. Imbalance in the system results in lukewarm floors or noisy radiators—and ultimately wastes energy.
Zoning and Control Strategy
For better control, divide the home into logical zones: living area, sleeping area, work area, and wet rooms. Give priority to the living room, while bathrooms may be warmer for short periods and bedrooms can remain cooler.
Preferably, control underfloor heating via supply temperature and early preheating. In contrast, control radiators via TRVs with small adjustments to avoid overshoot. It is also wise to limit the number of zones that demand heat simultaneously; this reduces peaks and keeps the heat source operating at an efficient point.
Cooperation With the Heat Source
Heat pumps prefer long, quiet operating hours at low supply temperatures. Therefore, a buffer tank and underfloor heating are excellent partners for them. Radiators can also participate effectively if they have enough surface area or fan convectors.
High-efficiency boilers, on the other hand, benefit from condensing at low return temperatures. Consequently, you should avoid excessively high supply temperatures in mild weather, otherwise, efficiency drops. Regardless of the source, set minimum and maximum supply limits and reduce switching behavior via hysteresis and minimum run times.
Floor Construction and Thermal Response
Your floor construction determines thermal inertia. A wet system with a thick screed has high mass, resulting in slow heat-up and cool-down times, which means you must plan preheating well in advance. Dry systems or thin screeds react faster but require more careful control to avoid temperature oscillation.
Furthermore, the floor finish matters: wood or vinyl has higher thermal resistance than tile, requiring a slightly higher supply temperature or longer heating time to achieve the same comfort.
Preparing Radiators for Low Temperature
To reduce the supply temperature further, you may need to increase the radiator surface area or improve convection. You can do this by adding an extra radiator, replacing old ones with low-temperature models, or installing radiator fans.
Additionally, ensure you clean the fins and bleed the system regularly, as air pockets drastically reduce heat transfer. While thermostatic valves provide flexibility per room, you must balance the system so the heat source isn’t forced to work against closing circuits.
Control Using Data and Predictability
For smart control, connect an outdoor sensor, supply and return sensors, and room temperature sensors per zone. You can then add weather forecasts to adjust setpoints and start times automatically.
For instance, solar gains can raise the temperature by 1–2°C on winter days; in such cases, you can shift preheating to a later time. With dynamic electricity prices, a heat pump can use cheap hours to charge the thermal mass within comfort limits. Monitor your consumption and runtime, and adjust your settings weekly.
Commissioning Checklist
Before considering the job done, bleed and flush the system, check pump settings and flow direction, and insulate pipes and the buffer tank. Set your supply limits and overheat protection, balance all loops and radiators, and record the initial values of the heating curve, flow rates, and ΔT. Finally, log comfort and energy use during the first weeks. Remember, small, consistent adjustments work better than big jumps.
Common Mistakes
  • Setting supply temperature too high "to be safe," which improves comfort but unnecessarily increases consumption.
  • Allowing all zones to call for heat simultaneously, forcing the heat source into inefficient short cycles.
  • Incorrectly placed mixing groups or a missing bypass, causing pumps to conflict with each other.
  • Ignoring floor finish and insulation, leading to unrealistic expectations and unnecessarily high heating curves.
Measuring Is Knowing
To truly optimize, monitor average and maximum supply, return temperature and ΔT per circuit. Watch the cycles per day of the heat source, the share of hours at low supply temperatures, and the comfort deviation from the setpoint. Finally, compare seasonal consumption normalized to degree days to see your progress objectively.
Do I always need a buffer tank with a heat pump?
Not always, but it is strongly recommended when the minimum output is higher than the actual heat demand, during defrost cycles, or with multiple zones that often close. It reduces cycling and stabilizes both flow and temperature.
What size should my buffer tank be?
A practical guideline is 10–20 liters per kW of thermal output, depending on the minimum output, control strategy, and system mass. If you have a lot of floor mass, you may choose a smaller tank; with little water content or many zones, a larger one is safer.
Can I run radiators at 40°C?
Yes, provided you have enough emitter surface area or use fan convectors. You should expect a longer heat-up time. Start with a lower heating curve and observe; where comfort lags, increase the emitter surface or give that room priority.
My underfloor heating reacts slowly — how do I plan preheating?
Start 60–90 minutes before the desired comfort moment. Increase this time on cold days or with heavy floor construction, and decrease it on mild days or with strong solar gains. Small setpoint steps (0.5°C) work better than large jumps.
Is a mixing group always needed for underfloor heating?
Only if you want radiators to run at a higher supply temperature. If the whole house can operate on low temperature, one regime is often sufficient, and a mixing group is not needed. However, do monitor flow and balance carefully.
What is a good ΔT for my system?
For underfloor heating, 5–7 K is a good starting point, while for radiators, 10–15 K is typical. Consistency is key: a stable ΔT indicates proper flow and good heat transfer. Adjust pump speed and balancing to achieve this.
