Homey Web App Changelog
Visit the Homey Web App
v1.11.34
  • Fixed an issue where emtpy sections would appear in the Flow card explorer.
v1.11.33
  • Added new device icons.
  • Added pre generated logic cards for weather and energy.
v1.11.32
  • Fixed an issue where the Flow card picker would crash.
v1.11.31
  • Update translations.
v1.11.30
v1.11.30
v1.11.29
v1.11.28
  • Added zone activity indicator to device tile.
  • Battery indicator now shows by default.
  • Fixed an issue where google translate would break the Advanced Flow editor.
v1.11.27
  • Added prefilled logic cards for numeric device tags.
v1.11.26
  • Updated node-homey-lib.
v1.11.25
v1.11.24
  • Added support for evcharger capabilities.
v1.11.23
v1.11.23
  • Add support for target temperature device indicator.
v1.11.22
  • Add support for Homey Pro mini.
v1.11.21
v1.11.20
v1.11.19
v1.11.18
v1.11.17
v1.11.16
v1.11.15
v1.11.13
v1.11.12
v1.11.11
v1.11.10
v1.11.9
  • Reduced error logging.
v1.11.8
v1.11.7
v1.11.6
v1.11.5
  • Fix korean language.
v1.11.4
v1.11.1
  • Fix alarm indicator color.
v1.11.0
v1.10.7
v1.10.6
v1.10.5
v1.10.4
  • Added support for Moods.
v1.9.77
v1.9.76
  • Added new zone icons.
v1.9.75
v1.9.74
v1.9.73
  • Added Matter pairing.
v1.9.72
v1.9.71
v1.9.70
v1.9.69
v1.9.68
v1.9.67
v1.9.66
v1.9.65
v1.9.64
v1.9.63
v1.9.62
v1.9.61
v1.9.60
v1.9.59
  • Updated translations.
v1.9.58
v1.9.57
v1.9.56
