Smart Automations for Maximum Solar Self-Consumption
Self-consumption as the new gold standard
As long as the net-metering scheme fully applied, it barely mattered when you used the solar power you generated. The kWh you fed back into the grid during summer simply returned on your annual bill. With the end of that scheme and a lower feed-in tariff, self-consumption—the direct use of your own solar energy—becomes the new benchmark. The higher your self-consumption, the less dependent you are on expensive grid power.
Smart automation for solar self-consumption is built on one simple idea: let appliances run when your panels produce the most. Instead of starting the washing machine whenever you happen to have time, Homey determines the optimal moment. It may sound like you’re giving up control, but in practice you barely notice. You decide what needs to happen, Homey decides when it’s most efficient.
By linking Homey to your solar panels, your P1 port and your major appliances, the system gets a complete overview of your household’s energy flow. It sees when you’re exporting to the grid, which appliances are available, and how much “surplus” solar power you have before energy flows outward. Based on that, Homey can switch appliances automatically—letting you use more of your own production and feed back less at a lower tariff.
Typical appliances for automated self-consumption
Most households have a few obvious candidates for energy-saving automations: washers & dryers, dishwashers, electric boilers, heat pumps, water heaters, and EV chargers. These are energy-intensive devices that don’t need to run at an exact moment. As soon as you add a bit of flexibility, countless possibilities open up.
With Homey you can, for example, set your washing machine to start somewhere between 10:00 and 16:00—but only if grid export exceeds a certain threshold. As soon as your solar panels produce enough, Homey gives the green light. You can add extra conditions such as a maximum start time or get a notification when the cycle finishes. You stay in control, while Homey makes the sun work for you.
The same applies to EV charging. You can set your charger to load slowly by default, but allow a higher charge rate when you have significant excess solar power. Or let the car charge only when your panels produce above a defined wattage. Aligning energy use with solar production becomes literally visible in your EV’s charging behavior.
From simple to advanced Flows
The beauty of Homey is that you can start small and scale up. Your first Flow might be simple:
“If export exceeds 1,500 watts, turn on the boiler.” If you find it works well after a few weeks, you can add conditions such as maximum water temperature, time windows, or even price-based triggers for those using dynamic tariffs.
Over time, Flows can be combined into an orchestration of automation:
- the washing machine gets priority during strong sun,
- the boiler uses the remaining surplus,
- the EV charges only when both have been served.
Homey Pro’s Advanced Flows help you visually build these complex scenarios, without writing a single line of code. Importantly, you can always lean on data. In Homey Energy you can see whether your automations actually increase self-consumption. If you still export large amounts at specific times, you can expand your strategy—perhaps adding an extra boiler or letting your heat pump respond more actively to solar production.
Tracking Success with Homey Energy and Insights
Automating your appliances is only half the battle; knowing how much you’ve saved completes the circle. By utilizing the Homey Energy dashboard, you can move beyond simple automation and into data-driven optimization. This tool provides a real-time breakdown of your household's power flow, allowing you to see exactly how much solar power is being diverted to your boiler or EV charger versus how much is still "leaking" back to the grid.
To take your self-consumption to the next level, you can use Homey Insights to analyze long-term trends. If the data shows you are consistently exporting power at 2:00 PM despite your current Flows, it’s a clear signal to shift another heavy task—like a pool pump or a dehumidifier—to a specific window. You can even use Logic Variables within your Flows to calculate your "Self-Consumption Ratio" automatically. By creating a variable that tracks (Direct Use / Total Production), you can have Homey send you a weekly push notification with your performance score, turning energy saving into a rewarding, automated habit.
Do I need to replace all my appliances with smart versions?
Not necessarily. Many appliances can be automated with smart plugs—as long as they start when they receive power. Modern washing machines and dishwashers often have a delayed start function that works well with smart switching. Newer devices with direct integrations make it easier, but they’re not essential.
Isn’t it inconvenient if I can’t choose when to do the laundry?
You always remain in control. You can set deadlines—e.g., the laundry must be done before 17:00. Within that window, Homey chooses the best moment. If you need to run a cycle immediately, you can override the automation manually.
Can automation respect noise levels and neighbour-friendly hours?
Yes. You can define time windows when certain appliances must not run, such as early morning or at night. Homey stays within your boundaries while still optimizing your energy use.
How do I know whether automation actually increases self-consumption?
You’ll see it in Homey Energy and in your feed-in pattern. If grid export decreases during sunny hours and more of your consumption aligns with your solar peak, your strategy is working. After several months, you’ll see it reflected on your energy bill as well.
Can automation combine solar production with dynamic tariffs?
Absolutely—this is one of the most powerful combinations. You can allow appliances to run when solar output is high or the price is extremely low. Advanced Flows let you combine multiple conditions for maximum benefit.
Will automation affect my daily routine?
Ideally, you’ll only notice that many things “magically” happen at the right time. Laundry is done when you come home, water is warm when you need it, and your EV is charged when you leave. You no longer need to plan manually, but you still have full visibility.
Is it safe to switch high-power devices automatically?
As long as you use certified smart plugs, relays and integrations, automation is safe. The electrical installation must be in good condition, of course. Large appliances like EV chargers and heat pumps already include built-in protections.
Who benefits most from automating for self-consumption?
Households with substantial solar power and a few flexible high-demand appliances benefit the most. But even smaller systems can reduce grid consumption and shift usage efficiently.
Does it take long to set up an effective automation strategy?
Not really. You can start with one or two simple Flows and expand them over time. It doesn’t need to be perfect from day one—iterating gradually often works best.
Can I adjust automations easily if my lifestyle changes?
Yes. You can update Flows at any time—changing triggers, time windows, or priorities. Homey grows with you as your home and habits evolve.
Self-consumption
The portion of your solar energy used directly in your home without feeding it back to the grid.
Flexible loads
Appliances that do not need to run at a precise moment and can be shifted in time.
Delayed start
A function on appliances like washing machines that allows scheduling a start time.
Prioritization
Assigning priority to certain appliances—e.g., boiler first, then washing machine.
Advanced Flows
Homey Pro’s advanced automation system for building complex multi-condition logic.
Charge rate
The amount of power used to charge an appliance, such as an electric vehicle.
Time window
The period during which an appliance may or may not operate.
